- Hammertown, USA
Wasn't sure, this was a 2wd that I shoved a high pinion in, a low pinion would've had tons of room. This one took some heat and some love.
was it the cat it was hitting? would it have cleared without cats?
Can't say I've thought that far ahead yet, but I'll probably hang it off the LCA mount.
This picture shows how much farther inboard stock LCA mounts are compared to the RuffStuff brackets. This was my plan but the shocks wouldn't clear the calipers at full lock.I used the LCA mount for a removable shock mount, useful for future changes to longer travel shocks.
When I changed from 9" to 11" travel shocks, it was easier for me to remove and replace the mounts with new mounts, having lower mounting holes, than to cut the old mounts off and welding new ones in.
Ironically, i Juuuuust installed the new bushings. Its no secret that I get most of the SFR stuff free, but its usually the prototypes or old generation stuff.
They are certainly way better than the Brown Dog stuff. There's still more vibe than stock, but its a lot less and you don't notice it as often. You do get a little extra vibes the first couple of days until everything settles.
Someone who has ORIs has given up on the concept of a vibe-free smooth ride.
I just put SFR mounts in. instantly less vibration than the brown dogs that were in there.
