Old January 9th, 2019, 21:34
XJFAMFUN XJFAMFUN is offline
Gear selection
I recently purchased a '93 Cherokee 4.0l that is sitting on 35s. Has Rustys 8 inch lift and long arm kit. It has the Dana 30 front and 8.25 rear axles. I am getting it geared, as it still has stock gears. The guy Im using recommended going with 4.56 gears for freeway/ daily driving/ trail/climbing. I was thinking more like 4.88s. Any suggestion or input fromanyone with actual experience wjth re geared set ups? Thanks.
Old January 9th, 2019, 23:40
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Gear selection
With 33"s and 4.56, my XJs freeway RPMs are not excessive, with 35"s 4.88s would be suggested.
You might want to drop it a few inches too.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old January 10th, 2019, 07:11
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Gear selection
Deeper is almost always better. 4.56 will put you closer to 'stock' than 4.88, but it does not compensate for the fact you went from spinning 150 pounds to spinning 400 pounds, and that does play a big factor.
Old January 10th, 2019, 08:12
Rockwood Rockwood is offline
Re: Gear selection
On the freeway, my XJ with 4.56s and 33s on steel beadlocks (got a deal, not really necessary for me since sub 15psi just means I just scrape the 8.25 everywhere) feels, er, sufficient power wise. In the hills, I wish I went 4.88. Only bummer about 4.88 on a D30 is you don't have much in the way of teeth on that pinion.
Old January 10th, 2019, 08:13
cal's Avatar
cal cal is offline
Re: Gear selection
You know, people say this.
But its the exact same engagement as a 4.56, and the 4.56's seem to break more.
Old January 10th, 2019, 09:35
LLLux31 LLLux31 is offline
Re: Gear selection
My vote would be for 4.88s. I have 37s with 5.13s and I'll be stepping up to 5.38s soon.
Old January 10th, 2019, 15:41
twinhauler's Avatar
twinhauler twinhauler is offline
Re: Gear selection
4.56s for 33s and 4.88s for 35s is like stock.
I had 4.56s on 35s for awhile and would be out of overdrive more. 4.88s will get you about 150 more RPM which isn't much but makes a difference for hill.
Old January 11th, 2019, 05:09
Mach2nh Mach2nh is offline
Re: Gear selection
fully loaded with gear on a 35s with a auto and 4.56s and it drives fine. even in the mountains of NH.
Old January 11th, 2019, 06:23
Re: Gear selection
Mach2nh: Honey are you upset?
XJ: No I'm... Fine.
Sent from my SM-N910V using Tapatalk
Old January 20th, 2019, 09:10
Re: Gear selection
Dud you guys notice a big power difference after you did the gears?
Old January 20th, 2019, 09:13
cal's Avatar
cal cal is offline
Re: Gear selection
Every time.
Old January 20th, 2019, 09:14
Re: Gear selection
I had mine done yesterday and I am kind of disappointed lol. I went with 4.56s. I expected a huge difference from the stock 3.55s, but its not anything crazy. I noticed i still have to have my foot in it and it downshifts and upshifts and downshifts going up a grade i normally drive
Old January 20th, 2019, 09:28
cal's Avatar
cal cal is offline
Re: Gear selection
What size tire
Old January 20th, 2019, 09:32
Re: Gear selection
35s. The guy I used to do the gears recommended 4.56s when I asked about 4.88s and so did the charts I found online. He said for a mix of regular road driving/trail/crawling i would be happier with 4.56s.
Old January 20th, 2019, 09:36
cal's Avatar
cal cal is offline
Re: Gear selection
Erm. You're a little under-geared. Adding a little power will help. 4.88 or 5.13 would have been better
Gear ratio selection, maintaining power with a lift and bigger tires md21722 Modified Tech Discussion 10 September 12th, 2015 09:10
AW4 gear selection - 2nd gear? anthrax323 OEM Tech Discussion 8 July 29th, 2010 08:45
DD gear selection--which brand? 1m4j2t Modified Tech Discussion 4 May 26th, 2009 19:20
MWC Rep selection...then what? BOB Midwest Chapter 7 April 3rd, 2005 20:50
Help in Gear Ratio Selection dialogue Modified Tech Discussion 3 January 26th, 2005 11:46
