Old January 3rd, 2019, 09:11
LLLux31 LLLux31 is offline
Structural integrity after removing inner wheel wells?
Wanted a sanity check before I go cutting stuff. I currently have 6" of lift and 37s. I want to get the most up travel possible but currently at full stuff I rub the inner wheel wells.
I don't want to lose any up travel. Here is where it rubs when flexed similar to the pic above. The green area has already been removed this was just an older pic. The red area is where it currently rubs.
Once I relocate the air box/battery can I just start removing the inner well or will it make it too weak?
The other rub area is the pinch seam. Anything that gets removed I would rebuild with 16 or 18g sheet metal. I know TNT makes a replacement panel but again I just want to make sure I'm doing this right before starting.
Any tips? Best practices?
Do I need a spot welder or can I do it with my mig welder?
Old January 3rd, 2019, 09:12
Re: Structural integrity after removing inner wheel wells?
This is the panel sold by tnt forgot to include it.
Old January 3rd, 2019, 10:15
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Most pinch seams are joining structural parts and would need to be replaced.
The inner fender liner forward of the coil spring mount and above the frame rail/front crossmember is not structural.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old January 3rd, 2019, 11:27
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
You may find this helpful.
http://www.ericsxj.com/cage/cage2.htm
Old January 3rd, 2019, 12:04
Thank you both.
That link is going to be a big help. I didn't even think about the fuse panel on the passenger side.
Old January 3rd, 2019, 13:20
denverd1's Avatar
denverd1 denverd1 is offline
great article. hard to believe that upper coil mount is responsible for supporting the vehicle, but I've never heard of them getting damaged.
Lux, have you pushed your axle forward at all? working on getting 37s undermine, but there's a ton of stuff like this involved.
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old January 3rd, 2019, 19:00
Mach2nh Mach2nh is offline
bump stops. Its all a out droop
Old January 4th, 2019, 12:12
Brent T Brent T is offline
Have you considered pushing the front axle forward an inch or two? Maybe then cut out and replace the piece in front of the wheel-well as planned and leave the pinch seam alone? My .02
Old January 4th, 2019, 12:17
Also I'm assuming you've already bent the pinch seam over? I cut in mine a couple spots and bent it over with a hammer. You can actually pound it back a little more for extra clearance without hurting anything. I seam sealed and painted mine once I was done massaging.
Old January 4th, 2019, 21:12
Heavyopp Heavyopp is offline
Any better pics of the girl in the drivers seat?
Sorry, can't believe no one else said anything...
Old January 5th, 2019, 10:09
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Not necessarily. I want all the uptravel I can get so I can actually go a normal speed in the desert. Tons of droop looks cool and all but having uptravel is equally important IMO
Old January 5th, 2019, 12:48
Ya i can see that. Out here in the northeast the only sand we have that you can drive on is a sand pit. No go fast stuff around here.
Old January 11th, 2019, 06:34
I'm planning on racing in Jeepspeed (with 35s for 2700 class) so limited on axle placement and what control arms I can run.
That's why up travel is important to me even though we're in NJ.
No not posting pictures of my gf/co-driver.
Pinch seam is pounded flat, and i will modify the hump where the intake/ecu and battery sit.
Once that's done I have T&J hydro bump stop mounts going in and will just adjust the bump.
Sent from my SM-N910V using Tapatalk
Wheel wells jslenk OEM Tech Discussion 0 November 28th, 2013 07:05
herculine wheel wells? cherokeeman90 Modified Tech Discussion 7 March 4th, 2008 09:56
Wheel Wells 78/xj88 OEM Tech Discussion 3 February 19th, 2008 13:06
Trimming Fenders and Wheel Wells chilibill Modified Tech Discussion 3 August 14th, 2005 00:54
rebuilt rear wheel wells cccj Modified Tech Discussion 11 November 5th, 2003 15:29
