1996cc
- Springfield, OR
I need an ignition switched 12v source for my pressure switch. Before I spend hours tracking one down with a light tester, does anyone know of a good spot to tap into in the engine compartment. (They're easy to find in the fuse panel, but I don't want to go clear inside the jeep)
Yes I know I can run straight from the battery, but with the switch I have, it will send 12v to the compressor (saden) if pressure is below 90. So if the pressure drops while the engine is off (from cold temps, etc...), it drains my battery - overnight.
Thanks.
Thanks.
