Old October 14th, 2020, 15:16
techno1154's Avatar
techno1154 techno1154 is offline
Re: Steering Gear Box
Originally Posted by Rob Mayercik View Post
I seem to recall someone in NAC having one of those many years ago (in the 2006 timeframe), but I don't recall how he liked it and a lot could have changed in the intervening years...
Yea! I do remember those comments. Matter of fact, earlier than 2006, many here on experimented with various forms of hydro assist with varying degree of success. In my opinion, many of them did it without prior fore thought. Things have changed now. There are many companies doing or suppling parts to convert any or most vehicles to hydro assist.
I remember the issue was brought up during the time of a former president aka Eagle who lived in Connecticut. I had the pleasure of wheeling with him during several NAC outings. (He was always very gentle on his MJ.)
Thanks for the heads up. However, with most burgeoning companies, there are many growing pains. For my sake, I hope they have overcome that.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old October 14th, 2020, 15:54
lordoeuf lordoeuf is offline
Well, I installed a Lee power steering pump w/reservoir on my '99XJ. I also used a Cherokee transmission cooler mounted infront of the radiators as a power steering cooler. Nothing like a new sealed pump to highlight the how much the gear box is loosing fluid out of the pitman arm fitting. Drips continuously now.
I was wondering if anybody has tried one of these '98/99 Durango reman gear boxes? Rockauto lists one from Lares and one from BBB Industries. As I live in Canada, so return shipping to USA is out of the question for the core. So $283 CAD for the BBB or $206 for the Lares (5 day wait on the Lares). Anyone have any opinions? I need to fix this soon as my daily driver is leaving puddles. I called all the local autopart stores and the cheapest for a Cardone was $500 + core.
Old October 15th, 2020, 13:28
Alright guys, I'll be the guinea pig. I ordered the Lares reman Durango gear box. It's substantially cheaper than the other options from PSC, Lee, and BBB new.
Old October 17th, 2020, 13:07
01classicxj's Avatar
01classicxj 01classicxj is offline
Originally Posted by techno1154 View Post
Have anyone here tried Redneck Ram? I had my steering gear repaired and ported for Hydro assist there but am yet to install it. Prices are good compared to others and a very good review.
https://www.westtexasoffroad.com/
I had sent my 89 Dodge W150 steering box and pump to West Texas Offroad year's, year's back. Got the ported upgrade. Ran 38" Swamper SSR's on swapped in Dana60's. Also switched to crossover steering. Truck drove fine on the highway doing 65. Offroad turned the 38's fine. So i never added the hydro assist. I also was still open carrier in the front though.
Old October 17th, 2020, 19:23
techno1154's Avatar
That is good to know. My spear time is taken up trying to sort out my front suspension issues.
In addition to having a bad steering gear which they did repair, I also wanted to reduce the load on the unibody exerted by the track bar by using the hydraulic ram.
Question,...Does the ported steering gear send fluid at pressure to both ends of the ram when driving straight? Reason for the question being, the steering stabilizer is not used by others when hydro assist is used.
Patrick
#594
Old October 20th, 2020, 22:17
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
I too am in the market for hydro assist... particularly for on the trail with the front locked.
I don't understand your question tho, Techno... are you asking if it is like pushing fluid from both sides making it under pressure when not turning? When turning each way it will push and pull fluid... like how the power part of power steering works, but with a ram aiding instead of just the fluid going from one end of the box to the other. Thats why where you drill is important when tapping the box.
I'm sure I didn't answer your question here is a helpful (maybe?) video
https://youtu.be/TAA9PhtDn-g
As for the steering stabilizer? I'd say sure it dampens the steering... but definitely no need to run both. I think a ss just masks issues with the steering that can be cleaned up. For instance,after going long arms (adjustable track bars and 1 ton steering) I haven't had a steering stabilizer on either of my jeeps- no death wobble
97 XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old October 21st, 2020, 06:17
techno1154's Avatar
Thanks for the video. It was very enlightening.
It did answer my question. There is (or so it seem) no fluid pressure is being applied to both sides of the ram if the steering wheel is not being turned and then it is applied to one side only.
I spent the first part of my career maintaining heavy construction equipment so I am familiar with the way they work. I just wanted to re-assure myself. And when a ram is filled with fluid it is extremely difficult to force it to move in or out thus contributing to the steering stabilizer effect and probably a lot firmer than OEM type stabilizer.
I have all the equipment here in the garage about 2 months. Just have not had the time to do the install. I sent in a box to Redneck Ram, had it repaired and ported and bought the entire kit.
Patrick
#594
Old October 22nd, 2020, 15:24
Ya I'm leaning that way more and more... I was going to have someone local help me port a box, but his schedule seems to be non existing so I like the idea of sending a box in to redneck, I have 2 stockers
Old October 23rd, 2020, 05:41
OK guys, I received the Lares reman gear box for a '98 Durango. I installed it, but the drive felt off, like too much force required to turn. So I pulled the gear box off and compared it with my old one. There are a few differences. One is that the diameter of the casting towards the front of the gear box (where that round disc is) is 0.5" smaller in diameter on the box RockAuto/Lares sent me.
Also, the engraved part number on my original Dodge Durango gear box is 26055055, while the part number on the Lares reman is 26000525. In looking up this information on Google, it appears as if they sent me the gear box for an 87-01 Jeep Cherokee. So this Lares Corp isn't even checking the core returns to ensure that they are Durango boxes. I'm guessing they are just assuming they are Durango boxes, but in 9/10 times, they are probably old XJ gear boxes.
I'm not sure what to do now. If I report the wrong part received on RockAuto and request a replacement, I'm pretty certain another XJ gear box is going to come.
Are there mechanic shops who can reman my original '98 Durango box?
For those of you who have successfully ordered a reman Durango box within the past few years, where did you order it from? What brand? Thanks.
Old October 23rd, 2020, 05:55
By the way, the diameter on the casing of my 26055055 - '98 Durango is 4.22". The diameter on the 26000525 - Lares reman is 3.82". For comparison, the diameter on my PSC box is 4.04". Note that the Durango box requires an additional 1/4" spacer on the bolts to mount to the chassis on an XJ.
Old October 23rd, 2020, 07:17
OK, now I am really confused. I called Lares about this discrepancy and was informed that the gear box w/plow is the one with the larger bore and the gear box w/out plow is the same as the XJ. The guy on the phone said that just because a Durango doesn't come with a snow plow, it doesn't mean that you don't have the snow plow gear box. I'm not sure if he was just trying to cover his butt there, or if this is indeed true. Have you guys ordered a Durango Reman w/out plow that was the larger bore?
Old October 23rd, 2020, 09:40
sdspearo's Avatar
sdspearo sdspearo is offline
Napa, but it's a crap shoot. Lots of commentary and issues to look out for in this old thread starting on page 8...
https://www.naxja.org/forum/showthre...=915103&page=8
If you were happy with your current Durango box except for the leak I would just replace the seals.
'96 XJ: Locked up D44's on 35" Milestar Patagonia's, ChroMo axles, 6" lift w/ 3 link front, 4 link rear, AX15, Atlas 5.0, Internal cage, DIY beadlocks, hydro assist, big ass stinger!, ...
Old October 23rd, 2020, 13:26
I do recall reading that thread and was left utterly confused. One guy says get the plow version, one guy says don't get the plow version. Some say 99 Durangos are all the same box, but rock auto still lists plow and non-plow for this model year.
I recall measuring about 3 full revolutions on my existing box, not 3.5. One side hits the stop on the knuckle, and the other side almost. Hence I don't see the insistence of some of the posters on getting the one with 3.5 revolutions.
Which is the seal kit I need for my existing box and what tool do I need to get it installed? The box works great other than it leaks a lot at the pitman arm shaft.
Old October 23rd, 2020, 16:20
sdspearo's Avatar
Not sure, but start here...
https://www.partsgeek.com/gbproducts/AC/1872-05211746.html?utm_source=google&utm_medium=ff&utm_ content=NC&utm_campaign=PartsGeek+Google+Base&utm_ term=1998-1999+Dodge+Durango+Steering+Gear+Seal+Kit+Edelmann +98-99+Dodge+Steering+Gear+Seal+Kit&utm_source=google& utm_medium=ff&utm_campaign=PartsGeek+Google+Baseci d=6774379819&aid=79287199093&keyword=323134563570% 3A%3Apla-323134563570&kid=323134563570&gclid=CjwKCAjw_sn8BR BrEiwAnUGJDtqalst-jKzq0XM7XMC0uMz-SPs0NKI12nbiPwbHc7jWaOrAPDpKLxoCEGgQAvD_BwE
or here....
https://www.napaonline.com/en/p/PSK7227?partTypeName=Power+Steering+Gear+Seal+Kit& keywordInput=pitman+seal
This guy even replaced his pitman seal with the box still in the vehicle...
https://www.youtube.com/watch?v=4GamcHl09XI
Old October 23rd, 2020, 18:58
I picked up the Edelman kit from Lordco just now. It only cost 2.5x what the American pay for the same thing.
I'll replace the pitman shaft seals and the cap gasket and hope for the best.
I suppose I could replace the other seals as well, but I don't have the tool that unscrews the steering wheel shaft side of the gear box. I asked the guy at Lordco if they had it and he said he's never heard of it. Do they have a specific name?
89 XJ Steering Gear Box, PS Pump, and Steering Shaft For Sale waxer SoCal For Sale 4 June 22nd, 2008 12:34
tight steering after steering gear rebuild finn188 Modified Tech Discussion 2 February 3rd, 2008 18:32
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 12:38
Need Steering Gear old_man Colorado Chapter 0 November 17th, 2005 08:29
Steering Gear greenday9d1 OEM Tech Discussion 7 April 6th, 2004 14:55
