Old June 18th, 2020, 08:10
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
Rear Leaf Replacement (3.5" OME Lift)
Looking for replacement rear springs and bump stops (one missing) for my '99 XJ.
Have complete 3.5" OME lift but rears seem to be flat, and feels/sounds like bottoming out on nearly any dirt road rut, bump or rock, even at very low speed. I did have probably 100# of gear in the back + spare tire rack on rear bumper, jack, rotopax (JRC). I've since unloaded but haven't test driven.
So, keeping it at 3.5" (33 x 10.50 w/4.56) can I get a recommendation on good spring packs and bump stops please? Just want to keep the height as is. The extra gear and tire rack need to be part of the equation I suppose.
Rubicon Express comes to mind but I haven't done any research for a few years so don't know what the favorites are these days.
Now that I have an elk tag it's come to me that I need to get this done.
Thanks for your time!
Edit: I might be looking to replace shocks as well. Guess I'd better get a buddy out to visualize what's happening.
1999 XJ Sport 4.0L Black
OME, ARB, JKS, AJ's, JCR, Rusty's Offroad, BFG, Black Rock, Vision-X, Warn, Spectre, Napier Precision, Kenwood, Daniel Stern...
Old June 18th, 2020, 10:20
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Rear Leaf Replacement (3.5" OME Lift)
Springs support the load, shocks control the compression and suspension cycling. If your suspension is bottoming out just from the load, I would suspect spring issues. If the springs support the load and the suspension compression is bottoming out, I would suspect worn out shocks first.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old June 19th, 2020, 04:41
75SV1 75SV1 is offline
My question is weather the springs collapsed or to much weight for the springs? Is this the newer style of OME springs with the dual rates? My thought is that OME springs are modular. So, if the springs did not take a set, then add another leaf.
I have not installed my 3.5" OME springs. They are the dual rate ones. I did consider the 3.5" set from IRO. It does have the option of an additional leaf.
Old June 19th, 2020, 05:39
Tim_MN's Avatar
Over compressing a leaf spring due to incorrect/missing bumpstops, or overloading leaf springs can damage them.
OME has light duty and severe duty springs, are your saggy ones the light duty part number ?
A leaf spring can be up graded by installing an additional leaf, I have done that to several XJ's to firm up a saggy stock leaf pack, or to build a custom suspension lift leaf spring. If the spring leaves are not damaged, a spring shop can re-arch them.
I installed the IRO KJ09122BK poly bumpstops and they work well.
Old October 17th, 2020, 09:46
NOTNSUV's Avatar
You Guys ROCK!
A leaf spring can be up graded by installing an additional leaf, I have done that to several XJ's to firm up a saggy stock leaf pack, or build a custom suspension lift leaf spring. If the spring leaves are not damaged, a spring shop can re-arch them.
Thanks Tim. Just found this post doing a search. I'd forgotten it was here. Gonna get it off the ground today and check things out closer.
Old October 17th, 2020, 10:31
NOTNSUV's Avatar
You Guys ROCK!
New pics.
Sent from my E6810 using Tapatalk
Old October 17th, 2020, 10:43
NOTNSUV's Avatar
You Guys ROCK!
Wonder if either of these are worthwhile?
Old October 17th, 2020, 10:58
NOTNSUV's Avatar
You Guys ROCK!
Looks like Deaver offers only 4" leafs for XJ. What'll that do with 3.5" OME front? It certainly isn't high in the rear as is.
Old October 23rd, 2020, 01:41
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
Ya man those look smoked to me...
I'm pretty happy with the IRO 3.5 leafs with add a leaf option. Be warned, the extra leaf is separate on delivery. Not overly hard to take the pack apart and put it in just, overly annoying.
Those new shackles will provide some more lift, but they are definitely beefier than the stockers and I'd throw em in when you install the new springs.
The shackle relocation brackets you got there will add some more lift too, and allow you to get the proper angle on your shackles. If I'm seeing them correctly they bolt in to the stock shackle location and in turn drop the new shackle mojnting location a few inches, thus creating more lift? Unless I'm seeing them wrong
For some reason they do look off to me, and I can't place it, maybe I just need sleep lmao! I'm a big fan of the SFR srb. While they are more work to install they are of the "no lift SRB" variety. Something it sounds like you could use instead of the ones ya got. It took some work to get the old crap out... being OCD I ended up dropping the gas tank and all that fun stuff. I don't think ida blown my self up grinding near the filler neck and vent tube.. but it was in the way too.
At 3.5 up front, the ass will definitely be up a bit with any new 3.5" leaf spring kit you throw at it (not to mention the shackles and SRBs ya got). Takes a few for it to settle down a bit, some added weight of a steal bumper and tire carrier speeds that up. Or just drive around with sand bags in the hatch!
You could always throw a spacer up front as well. Not sure how the rest of your suspension is set up or if thats doable or not, but a cheap way to level her out
97 XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old October 23rd, 2020, 11:41
maxbraketorque maxbraketorque is online now
Your shackle box looks to be collapsed, but perhaps it just appears to be the case due to the close-up wide angle photo.
Old October 23rd, 2020, 18:41
Oh, good call out... I'm on my phone and the pics are monstrous, I totally missed that. Ya man, that thing is fubared fosho.
I don't know that the Shackel Relocation Bracket you have will still be able to mate to that... as my long-winded post hinted to, the nonlift SRB might serve you better- now with the damage here makes even more sense, as you have to cut that box out to install them. StinkyFab makes a dope one, but there are also others... as I already said I'm happy with my purchase, its a stout design, perfect bends, and had great customer service through and through. Not trying to sound like I'm tryna sell ya something tho, so ya: no lift Shackle relocation brackets
Should be in your near future
Old October 23rd, 2020, 19:17
Originally Posted by ShoeterMcgav View Post
Oh, good call out... I'm on my phone and the pics are monstrous, I totally missed that. Ya man, that thing is fubared for sho.
Impressive if it is actually collapsed. Ironman4x4fab SRB also looks very nice. Great that there are many choices.
Replacement rear shocks 5.5" lift question cliff h Modified Tech Discussion 7 June 14th, 2015 20:56
4.5" lift rear leaf ID, help me fix terribly harsh ride madmike283 Modified Tech Discussion 7 October 25th, 2010 18:24
USED 6" lift rear leaf springs - Teraflex piercejeeps MWC For Sale/Wanted Forum 10 October 15th, 2008 08:38
Rear leaf springs with around 4-4.5" lift spctrbytz Wanted: Private Party Only 0 June 14th, 2006 06:18
Rear leaf springs 3-4" lift, Dakotas? woody431 Wanted: Private Party Only 2 September 25th, 2004 21:55
