Old October 16th, 2020, 15:34
Vince's Avatar
Vince Vince is offline
Anyone successfully done EVAP delete
So I have a P0443 code today and looking at the cheapest parts to replace the EVAP Purge Solenoid and Pigtail will probably cost $65 after shipping and taxes to the UK. My solenoid is probably OK but I don't have a spare in any case.
Then I started thinking... why do I need the extra complexity of EVAP anyway? As long as my tailpipe emissions are within legal limits and the CEL is not illuminated, my Jeep will pass the emissions test.
I reckon I need a 48w 36 Ohm resistor to fake the presence of the purge solenoid to the PCM. I would need to vent the fuel tank to atmosphere presumably. But what to do about the LDP (Leak Detection Pump)?
Anyone done an EVAP delete without causing CEL to be illuminated or DTCs.
Old October 23rd, 2020, 16:44
tech1001 tech1001 is offline
Re: Anyone successfully done EVAP delete
I think if you go down this road you will have more problems then you think you are fixing .
Old Yesterday, 10:05
Vince's Avatar
I'm inclined to agree.
Old Yesterday, 15:36
Cummins90 Cummins90 is offline
This was my experience with a 99 XJ.
There is a large bore "s" shaped rubber hose coming off the LDP. I capped that. Now the LDP would pressurize just the s tube. No leaks so the light would stay off.
Successfully Tricking the NSS in multiple Positions? themauler OEM Tech Discussion 1 September 13th, 2013 23:25
Has anyone successfully installed a M90 Supercharger? JeeperYJ Modified Tech Discussion 9 December 12th, 2012 09:00
Calling all those who have successfully performed the KJ disc swap (8.25") anthrax323 Modified Tech Discussion 6 February 9th, 2012 10:39
small evap leak and lart evap leak? kdub41 OEM Tech Discussion 2 January 26th, 2010 15:50
Can you successfully bypass the heater valve? BIGSLVRXJ OEM Tech Discussion 30 March 10th, 2006 06:46
