Old January 12th, 2019, 19:36
cpefy3 cpefy3 is offline
Bird Box Challenge
Today I had the distinct pleasure of doing the “Bird Box Challenge” XJ style. What is this you ask? Trying to locate and screw in the bottom 4 manifold bolts. That is all I kept thinking while I fumbled through trying to hold the intake manifold in place while trying to screw them in place. I would love to see how they did this in the factory. Hope everyone had a great Saturday!!
Old January 12th, 2019, 21:51
lawsoncl lawsoncl is offline
Re: Bird Box Challenge
[QUOTE=cpefy3;246625024 I would love to see how they did this in the factory.[/QUOTE]
Prior to installing the engine into the vehicle.
Old January 12th, 2019, 22:00
Ewenm's Avatar
Ewenm Ewenm is offline
i screw the lower bolts in a couple of threads and then wiggle the manifold into place.
once the gasket is in place and the outer extractor bolts are in place is fairly easy, its the tightening go those two lower rear bolts that's the killer, especially with after market extractors i hurt for days after.
Old January 15th, 2019, 14:34
Red91Laredo's Avatar
Red91Laredo Red91Laredo is offline
Yep, those bottom bolts you pretty much have to tread in by feel since you really can’t see where they’re at. I get them started a couple threads and then slide the manifold onto them as stated. A 14mm swivel socket is really helpful and may even be required to tighten the bottom rear bolt if you’re running an aftermarket header.
Old January 15th, 2019, 15:29
cruiser54's Avatar
cruiser54 cruiser54 is offline
Removed the air cleaner assembly?
Old January 15th, 2019, 15:40
Ewenm's Avatar
man that would be the FIRST thing wouldn't it??
then the front prop shaft to get at the two lower rear most bolts.
basics
Old January 15th, 2019, 15:45
cruiser54's Avatar
basics
It is for me.
You guys know the electrical tape in the socket trick?
Old January 15th, 2019, 21:41
Ewenm's Avatar
yep
sorry it a bird pic kennzz05 TEST Forum 1 May 6th, 2009 12:23
Take down the bird feeder TRNDRVR Non-Tech / Off Topic 105 May 7th, 2008 20:09
New bird dog! SCW Non-Tech / Off Topic 5 December 30th, 2007 09:55
It's a bird! It's a plane! It's a... IXNAYXJ Non-Tech / Off Topic 11 July 8th, 2006 10:41
8.8 from T-Bird woody431 Modified Tech Discussion 6 April 1st, 2004 13:20
