Old April 22nd, 2012, 20:54
Slonopotam's Avatar
Slonopotam Slonopotam is offline
NAXJA Member #1358
Front Bilstein 5100 install question
Hi,
I installed 5100 on the front today. When I tried to tighten the top nut, the bolt protruding from the shock started to rotate freely. I noticed there was an internal hex on it, so I held the bolt still with a hex key.
Why was it rotating? Was it some kind of adjustment?
Thank you,
Andrey
Old April 22nd, 2012, 21:07
ADVNTURR's Avatar
ADVNTURR ADVNTURR is offline
I worry when rattles stop
Re: Front Bilstein 5100 install question
The piston in a shock has nothing to prevent it from rotating internally (cylindrical body with a cylindrical piston). All shocks and struts (that have a plain stud top) have some feature on top of them to allow the person installing them to hold it while the nut is tightened. The better aftermarket companies who realize that their products will be installed in garages without the specialized tools used on the assembly line are kind enough to put male/female hexes in the end of the shafts, other companies aren't so nice and puts odd shapes on the end which are next to impossible for the average person to hold and develop proper torque.
Old April 22nd, 2012, 21:44
DanMan2k06 DanMan2k06 is offline
Some old rubber tubing/oil line/rad hose and a pair of vise grips. Done.
Old April 23rd, 2012, 07:29
Tacedaddy's Avatar
Tacedaddy Tacedaddy is offline
^ this
Bilstein 5100 quick question. casual JeepSpeed, Prerunner and Competition Tech Forum 27 September 11th, 2011 09:43
2 Front Bilstein 5100 4.5-6.5" Lift cpolish24 Arizona For Sale/Wanted 5 September 20th, 2008 16:54
Bilstein 5100 quick install question. Calata OEM Tech Discussion 6 April 18th, 2006 16:27
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
