Old March 19th, 2013, 21:58
mstockwell41's Avatar
mstockwell41 mstockwell41 is offline
axle hub help please
ok so i replaced my front hubs on my 88 wagoneer and torqued them to 175 and the problems began. when i tried to drive away it acted like the ebrake was on. I lowed the torque on the axle nut like a car (until the wheel would slightly spin) and checked the torque and it was around 50. If i go higher it wont even move. Any ideas?
Old March 20th, 2013, 04:05
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
Re: axle hub help please
What brand hubs did you buy?
Sounds like they're bad to me
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 5" lift, SFR Long Arm, Deavers, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old March 20th, 2013, 05:55
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Are they hubs for an '88?
Old March 20th, 2013, 06:47
MaxxXJ's Avatar
MaxxXJ MaxxXJ is offline
Did you put the washer back in when you replaced the hub?
Old March 20th, 2013, 10:40
I bought carquest premium. I put the washer back in and they match the old ones. When i removed to old ones tbey were loose as well. They work fine when tightned like regular wheel bearings but i know tbey wont last if not torqued.
Old March 20th, 2013, 13:07
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Have you confirmed that the axle/knuckles/brakes are renix era? That may be the problem
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old March 20th, 2013, 13:17
kastein's Avatar
kastein kastein is offline
2wd or 4wd?
2wd XJs/MJs use regular spindles until around 92.0, 4wd XJs/MJs all use unit bearings.
if you have spindles, it would make a lot of sense that you have issues with them when they're subjected to unit bearing torque levels!
My yard looks like Sanford & Sons.
Current crapcan fleet: LS swapped bobbed 79 J10 Honcho, 4x4 auto 4.0 8.25 swapped metric ton 88 MJ
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old March 20th, 2013, 13:25
Im not sure. They were the only hubs that the salesman said carquest made for the 88 wagoneer.
Old March 20th, 2013, 13:36
kastein's Avatar
Can you take a picture of the hub and brake rotor? Does the brake rotor come off the bearing assembly?
Old March 20th, 2013, 14:54
I can i get off work at 1800. The rotor does seperate from tbe hub.
Old March 20th, 2013, 14:55
It is a 4wd
Old March 20th, 2013, 20:24
the one on the left was in the jeep, the one on the right is what they gave me.
Old March 20th, 2013, 20:33
Well i cant figure out how to post pictures. I figured out they sold me the wrong ones, the old ones the bearings were level with the hub surface and the new ones the bearings are recessed into the hub and have a seal that goes around the axle. The axle was rubbing on the hub, it was wider than the bearing surface. As soon as i figure the intraweb out i will post pics.
Old March 20th, 2013, 20:37
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
Your tag usage is right, but you've used a bad URL.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old March 20th, 2013, 20:45
Thanks, i will get it right soon! Best thing about 4x4 crowd is everybody loves to help.
relocation the lower control arm mounts on the axle to the top of the axle? ericfx1984 Modified Tech Discussion 30 March 23rd, 2012 12:17
axle u joint issue - may have destroyed my axle shaft moximouse OEM Tech Discussion 5 July 10th, 2011 13:22
Axle U-Joint Choice and Axle Tube Seals 97stomper Modified Tech Discussion 20 April 17th, 2010 11:24
Axle leaking oil out passenger side axle tube redneck OEM Tech Discussion 2 August 4th, 2007 17:04
NEW XJ Axle U-Bolts for Chrysler 8.25 Axle Asking $20 Shipped 92westshady For Sale: Private Party Only. XJ ITEMS ONLY 5 June 26th, 2007 21:04
