IIRC, you initially had a BA10/5 and swapped to the AX-15, correct? If so, did you move the crossmember? I read recently, about the cross member being in the further forward position on the frame rails, and it needs to be moved back for the AX-15. And as far as that goes the mount for the AX-15 is plug n pray as is.
