Old March 14th, 2018, 23:23
bradleyheathhays bradleyheathhays is offline
What this thing that's clicking under my hood?
96 XJ..
The sounds coming from this thing right in front of the pass firewall. It clicking 2-3 times a second loud enough you can hear it w/ the hood closed. It's done this a couple times before but I never tracked down the sound. No clue what it is.
Old March 14th, 2018, 23:36
Re: What this thing that's clicking under my hood?
Sorry don't know why the picture is so big.
The sounds coming from a part right in front of my pass firewall. It's a short vertical cylinder w/ 2 vac lines on the bottom and an electric connection at the top. Its clicking 2-3 times a second, loud enough you can hear it w/ the hood closed. It's done this a couple times before but I never tracked down the sound. No clue what it is.
Old March 15th, 2018, 06:48
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Iíve heard it called fuel purge solenoid, looking it up itís called Duty Cycle EVAP Canister Purge Solenoid
Seem like they are supposed to tick.
Is it throwing any codes?
Old March 15th, 2018, 07:30
JeepNoob JeepNoob is offline
It is and they are. It opens and closes to allow fuel vapors, if I remember right, from the charcoal canister, into the intake manifold under certain operating conditions.
Old March 18th, 2018, 11:20
2X_01_Jeeps 2X_01_Jeeps is offline
Faint tick-tick-tick-tick sound?
On my 2001 jeeps that would be a very small pump that is pumping air into the emissions system and the gas tank to test the integrity of the system.
Only runs when the gas level is somewhere less than Full and only runs for a little while after startup. If the test fails 3 (I think) times it throws a code.
Old March 18th, 2018, 15:29
sinat01's Avatar
sinat01 sinat01 is offline
it will throw a code for EVAP leak usually if it fails, but it is a leak detection pump. if I remember right it pressurizes the fuel tank to like 1/4PSI to check for leaks
Rear wiper motor clicking but not turning - Installed napa motor same thing SBpunk OEM Tech Discussion 2 June 12th, 2013 19:21
Hood vents versus hood cowl/scoop Tryfan OEM Tech Discussion 8 April 22nd, 2012 08:01
Ditch the hood prop! - Infinity Q45 hood struts - PICS s14unimog Modified Tech Discussion 17 May 27th, 2011 15:29
What is this thing attached to my hood? Dozer11B OEM Tech Discussion 17 September 18th, 2009 23:32
Hood Pins? Giving up on crappy hood releases gmars Modified Tech Discussion 2 October 24th, 2006 14:20
