Old March 24th, 2020, 21:29
1WhiteXJ 1WhiteXJ is offline
27 or 30 Spline Shafts for Dana 30?
I know this has been covered a few times here before, but the last discussion I could find about this was from a few years ago...
I want to lock the Dana 30 and I'm looking for opinions on the 27 or 30 spline upgrade debate. I can see both sides. With 27 spline, you can carry spares if you happen to break one. But, I like the idea of NOT breaking so 30 spline appeals to me. Plus, at this moment, I can get 30 spline shafts for less than 27's. Have at it. Thanks!
Old March 24th, 2020, 21:36
RCP Phx RCP Phx is online now
Re: 27 or 30 Spline Shafts for Dana 30?
I like to have things factory for trail fixes, everybody I run with carries different items but they are interchangeable. I never broke my factory axles in 18yrs but I did upgrade to chromo's recently while I was doing my WJ brake upgrade.
Old March 24th, 2020, 21:46
Is your Dana 30 locked?
Old March 24th, 2020, 22:29
Yes, I run a ARB in front.
Old March 24th, 2020, 22:31
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Upgrading to 30 spines moves the weakest point from the axles to the ring and pinion. Guess which one is easier to replace, especially while on a trail.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old March 25th, 2020, 08:56
denverd1's Avatar
denverd1 denverd1 is offline
29 spline is the newer stock dana 30
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old March 25th, 2020, 09:00
NOPE!
Old March 25th, 2020, 09:02
denverd1's Avatar
I mean you can build it to 30...
I can build my 44 to 35, but the $ required is pretty crazy
Chili Pepper '98
Old March 25th, 2020, 13:28
denverd1's Avatar
what else have you done to polish that turd?
Chili Pepper '98
Old March 25th, 2020, 15:21
srb531 srb531 is offline
i recently broke a chomoly 27 spline short side inner, but it did hold up fine for 5 yrs of abuse. it was still under the ten yr. warranty,so quadratec sent me a new complete set of g2 27 spline front axle shafts, inners , outers w/ u joints installed. all they ask was return the old kit & they paid return shipping , im impressed.
Old March 25th, 2020, 15:31
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I have done the 30 spline upgrade a couple of times. I don't buy in to the "moving the fuse to the ring and pinion" junk because 27 spline guys break those all the time as well.
That said, for what little upgrade it is, I would not bother upgrading to 30 spline again. Would just buy good 27 spline chromo stuff.
Old March 25th, 2020, 20:59
That's good to know they sent you a new set at no cost to you! Just curious, what size tires were you running? Locked?
Old March 25th, 2020, 21:01
Thanks. I'm now leaning toward the 27 splines simply due to I already have stock spares ready to go. I highly doubt I'll ever need them, but never say never...
Dana 30 - 30 spline shafts ocean_jet Modified Tech Discussion 2 July 7th, 2008 18:24
dutchman 35 spline dana 44 shafts? proskier101 Modified Tech Discussion 12 May 2nd, 2008 05:16
WTB 30 spline axle shafts dana 30 XJpoopbrown NAC Classifieds 7 December 4th, 2007 10:12
33 spline dana 44 alloy shafts $175 ktm racer 419 NAC Classifieds 1 October 28th, 2007 19:35
