Old August 1st, 2019, 11:00
Black1990jeep Black1990jeep is offline
Front Drive Shaft U Joint
I want to replace my front drive shaft you joint, the one on the dana 30 front diff of my 1990 XJ. I see two Spicer brand U Joints listed...
5-1310-1x and 5-153x Both are greasable, which is what I prefer. what is the difference in them other than price $35 verses $10 respectively.
Are those the correct joints? Which is prefered?
Thanks!
Old August 1st, 2019, 11:36
RCP Phx RCP Phx is offline
Re: Front Drive Shaft U Joint
The one I know of is the 1310, standard for a front driveshaft and rear driveshaft.
Old August 1st, 2019, 12:32
cwyman6 cwyman6 is offline
Gonna be the 5-153x.
Old August 1st, 2019, 13:17
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
1310 is the size. 5-153x is the part # for Spicer.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old August 1st, 2019, 13:44
https://www.dennysdriveshaft.com/p33...ompact_fr.html
https://www.dennysdriveshaft.com/p33..._compact_.html
The two links above show the two different joints, both Spicer, both same application. Grease fitting different location as seen in photographs.
Is there a difference in strength if they both fit?
Looks like the expensive U Joint 5-1310 can also be used on the double jointed cardan end of the drive shaft, were as the cheaper priced 5-153x should not be used there do to it's grease fitting location.
So strength wise, is one better than the other for the differential end of the front drive shaft?
Old August 3rd, 2019, 07:43
trippled trippled is offline
1310x would be my choice, with fitting on the cap. I usually prefer the non greaseable joints as I think they last longer and have better seals and may have a slight increase in strength.
Old August 3rd, 2019, 07:58
Most driveshafts use the 5-153 but you need to be aware of which way you face the grease fitting.
Old August 3rd, 2019, 08:42
One thing about having the zerks on the caps is that they are easily broken off on rocks. They do make flush fittings but they still get damaged.
Old August 5th, 2019, 06:07
What are you going to do about the rest of the shaft(slip-yoke,centering ball, and the other 2 u-joints)?
Old August 6th, 2019, 05:22
The rest of the axle seems ok. the forawrdmost U joint refused to take grease on one of its four ends, ie no grease came out one of the four cap seals.
Old August 7th, 2019, 12:23
Just because grease didnt come out of one cap is no reason to change the joint. Drive it for a week and regrease if concerned.
Is this front drive shaft / Cardan Joint salvageable bogaski OEM Tech Discussion 4 January 29th, 2012 05:04
front drive shaft u-joint Steelghost OEM Tech Discussion 7 April 27th, 2011 15:33
Double Cardan Joint on Front Drive Shaft DoctorK OEM Tech Discussion 6 August 1st, 2010 01:48
Stiff joint in front drive shaft kenny schmitt OEM Tech Discussion 3 July 8th, 2007 07:45
front drive shaft u-joint XJensen Sierra Chapter 12 May 9th, 2007 15:56
