Old March 14th, 2019, 16:32
BAXJ96 BAXJ96 is offline
A couple mod questions
I have a couple things Iím curious about but each on their own is not enough to warrnt a whole thread. So I figured I would put them all together.
1st question. Is there a data buss I can tap in a 96xj? I have installed an overhead console from a 97? Zj and it works well enough but I would like if I could get data from the ecu to show trip mileage, mpg, miles to empty etc. I have read the overhead console write up and it has lead me to believe there is a buss somewhere I can tap but I donít know where that is.
2nd question. What degree shim do I need for a 4.5 inch lift and no crosmember drop? I am removing the drop and I need a new shim I believe.
Lastly. Does anybody know if itís legal in mass to delete the tail pipe and dump the exhaust right out the muffler before the rear axle.
Any help on any of these would be awesome thanks!
Old March 14th, 2019, 16:49
Re: A couple mod questions
I just realized that I posted this in OEM rather than modified. Face palm. Can someone give me hand getting this moved please?
Old March 15th, 2019, 08:00
JeepNoob JeepNoob is offline
According to the Mitchell wiring diagram I looked, the '96 does have a data bus, but it runs directly to the OBD II port and nothing else. I wouldn't be surprised if a factory '96 PCM doesn't even have the functionality you're looking for to begin with.
As far as getting rid of the tailpipe behind the muffler, legal or not, I wouldn't do it. Did it on my '96 (got rear-ended. Jeep still ran and drove but the tailpipe was crimped and trashed, so I just cut it off) and the new exit right from the muffler ended up being right next to the U-joint for the rear diff. A professor of mine (who's been an ASE-certified master mechanic since 1976) saw that and asked in a "you-know-better" sort of way if I thought dumping all that exhaust heat right next to the U-joint was the best thing for the grease in it. I agreed it wasn't, but also told him I planned on replacing the entire exhaust with a performance system anyways.
Old March 21st, 2019, 06:17
Thanks for the info. I will try tapping the buss at the port, if I donít get any readings than oh well, nothing ventured nothing gained. As for the exhaust, that is an excellent point I had not thought of. Come to think of it itís probanlt not great for the temperature of the diff either.
Old March 21st, 2019, 12:45
smccollamjr smccollamjr is offline
More than temperature is increased possibility of getting fumes inside the vehicle especially while stopped in traffic. A couple guys got killed from that here a few years ago. They had an old Bronco II and got high centered off road on a cold night. They decided to sleep in the Bronco a few hours until the sun came up. The exhaust was junk and they left it running. They never woke up.
Old March 21st, 2019, 20:40
Another excellent point. Considering how, caugh caugh, “air tight” or “waterproof” my xj is it now sounds like a very bad idea. Thank you for the input.
Old March 22nd, 2019, 05:00
denverd1's Avatar
denverd1 denverd1 is offline
Yep exhaust has to dump beyond passenger area.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old March 22nd, 2019, 07:43
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Done. Just noticed the request.
In the future you can hit the ! icon at the top of a post and report it with that request so that we get notified.
Old March 22nd, 2019, 15:11
Thank you. I was not sure if that was proper use of the ! Button
new guy, couple questions.. DZRTRAT Non-Tech / Off Topic 13 May 19th, 2011 15:20
Couple BA-10/5 questions tchase OEM Tech Discussion 5 January 20th, 2010 23:17
A couple questions about a couple different things Hubbazoot OEM Tech Discussion 2 May 26th, 2009 00:33
Remanufactured motor questions couple of questions.... pikey77 OEM Tech Discussion 5 May 29th, 2008 06:14
couple of questions ncwheeler Modified Tech Discussion 3 January 10th, 2005 15:13
