Old October 23rd, 2005, 14:23
88XjLaredo's Avatar
88XjLaredo 88XjLaredo is offline
Transmission Rebuild Cost
I've got a 1988 Jeep Cherokee Laredo with the I-6 4.0. I just recently hit 220k and the transmission is starting to slip. Does anyone know how much it will cost to rebuild because I certainly have no idea. I live in the Chattanooga, Tn area so if anyone lives near me I would greatly appreciate some recommendations on who to go to around here.
Old October 23rd, 2005, 14:42
Bowzer Bowzer is offline
Re: Transmission Rebuild Cost
hmm... off the top of my head, around $500
if you have the AW4:
"Includes Overhaul gasket & seal kit, all friction plates, all steel clutch plates, flex band (if required), filter & bushings and all friction and steel clutch plates."
Price: $214.64
Manufacturer: Omix-Ada
Part Number: 19001.03
http://www.4wheelerssupply.com/catal...ducts_id/70848
Old October 23rd, 2005, 14:45
karter74 karter74 is offline
cheapest i was quoted was 1200 but that is when u drop your car off at the shop and pick it up when its done....
Old October 23rd, 2005, 17:03
peeweexj peeweexj is offline
I'm guessing $1400. You have to be a real good mechanic to rebuild one yourself.
I would just pick up a used tranny (thats been tested), and install, or have it installed.
Old October 23rd, 2005, 18:37
96 Cherokee 96 Cherokee is offline
I could tell you a sad horror story about how an AW4 rebuild at a Chrysler dealership cost me about $5000.00 in 2001, but I don't want to bring up those painful memories.
Old October 23rd, 2005, 18:51
87manche's Avatar
87manche 87manche is offline
if you want a warranty buy a reman
http://www.phoenixhardparts.com/inde...S&Category=531
$825, install on a 93 Chrysler minivan cost $300 at the local mechanic. Probably less for a jeep, they all but had to pull that v6 in the van, silly FWD cars.
Old October 23rd, 2005, 19:10
RockTracXJ's Avatar
RockTracXJ RockTracXJ is offline
haynesn12's Avatar
haynesn12 haynesn12 is offline
when my mom had hers done it her 99 taurus it was over 1000 easily. when i blew the tranny in my f-150 i went and bought a tranny from a jy for 300 and then had a local mechanic install it for another 300, so 600 total and it is still going strong since i sold it to my dad.
Old October 23rd, 2005, 19:54
BIGSLVRXJ BIGSLVRXJ is offline
My 90's AW4 was $1499 out the door.
Old October 23rd, 2005, 21:37
MACH90XJ's Avatar
MACH90XJ MACH90XJ is offline
$1500 is in the ballpark including labor, but for gods sake make sure your TPS is not the actuall problem which it usually is. A simple volt meter test will rule it out. Theres been plenty of victims of un-necessary rebuilds.
Old October 24th, 2005, 19:58
88XjLaredo's Avatar
thanks for the info guys!
Transmission rebuild cost???? 96country OEM Tech Discussion 14 September 3rd, 2011 03:57
Another AW4 transmission problem dragula OEM Tech Discussion 8 February 3rd, 2009 16:45
Cost for rebuild civiceg22 OEM Tech Discussion 2 September 7th, 2005 00:26
how much should it cost to rebuild 89 xj engine lapaul OEM Tech Discussion 15 February 23rd, 2004 22:51
CJ Rebuild progress update... Skorpyo North Atlantic Chapter 1 November 20th, 2002 13:59
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
