Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Comanche MJ (1985 - 1992)
Jeep Comanche MJ (1985 - 1992) Jeep's Cherokee-based compact pickup technical forum.
Old March 17th, 2021, 12:28
Wolperdinger Wolperdinger is offline
Bad Vibes -Pilot Bearing? Release Bearing? Other Bearing?
Got an 89 MJ that was converted into 4WD, but not by me so it's a bit of a Frankentruck. Started getting really bad vibrations when under power. Checked all the U-joints, and they're all good. Took out the front drive shaft to make sure that wasn't it, and it's still the same. Now it has started to make a screech that is definitely coming from what sounds like right under the shifter. The noise lasts for about 5-10 seconds after start up and then goes away. Not sure what transmission it is, but the slave cylinder is on the outside, if that helps. Wondering what you guys think. Pilot bearing? Release Bearing? Some other bearing? The vibes only happen under load. When the clutch is pressed in when driving, the vibes stop.
Old March 17th, 2021, 12:29
Re: Bad Vibes -Pilot Bearing? Release Bearing? Other Bearing?
Oh, I posted in the XJ forum because I'm pretty sure that's where the tranny came from, but I don't know for sure.
...Looks like it is in the MJ forum and I can't edit or delete. Ooops!
Old March 19th, 2021, 19:42
David_Bricker's Avatar
David_Bricker David_Bricker is offline
PSR Fire Marshall
Location: Upstate NY-live; Death Valley-play; Hawaii-working on it
Is it were the pilot bushing / bearing, it would likely change as the clutch was depressed. If it only happens on first first up when cold, it may also be the fan/serpentine belt squealing.
External slave cylinder means an AX-15. Since an '88 MJ (or XJ) would not have likely come with an AX-15, it's possible the pilot bearing has the wrong inside diameter. This happens particularly when doing a stroker conversion, as the earlier crankshafts have a different pilot hole diameter.
When I had this issue, here is the info I have from my research:
Pilot bushing #PB-122
OD: 1.055"
Pilot bushing #PB-117
OD: 1.055"
Pilot bushing #PB-207
OD: 1.001"
I got this info from Phoenix Friction Products, from whom I bought my kevlar clutch kit and flywheel. They can supply those bushings, though they should be able to be cross-referenced at a local parts store. This was the clutch kit I used: http://www.phoenixfriction.com/p-407...-10-12-in.aspx
The 4.2L crank that is used on a stroker has a hole of 1.056"
The 4.0L crank that is in Renix and HO motors has a hole of 1.001"
The early model AX-15 trans (before 1991-ish?) has a input shaft of 0.580"
The later model AX-15 trans has an input shaft of 0.755"
Note that these sizes aren't exact. For example, the trans input shaft is slightly smaller. My trans mic'ed at 0.752".
I think drilling out the bushing is likely to not be all that accurate.
Mine would squeal when the clutch was engaged, and be quiet when disengaged.
David Bricker / SYR
Gomer - '95 XJ, 2 dr. 4.6L Russ Pottenger Stroker; Novak TJ AX-15; Black Box 2.72:1 + 241OR 4:1; RockJock 60 Front, hydro assist, Hi-steer; D60 trussed and shaved rear; 4.56 ARB Front and Rear; Black Magic discs, Bilstein 7100s front and rear; 35s; PRP seats; Warn PowerPlant winch, hybrid cage. Annd, the Faux Dorkle is gone.
National Treasurer 2013-2023
Not a member? Become one today, and help support YOUR club.
Old March 21st, 2021, 21:38
Anak's Avatar
Anak Anak is offline
Stranger
The release bearing could indeed be the culprit. Most clutch kits come with a cheap release bearing, and most folks go ahead and install that bearing.
If I were you I would try to locally source pilot and release bearings. That way it should be easier to return the parts you don't need.
Count yourself lucky that you are at least getting a warning from whatever is going south.
Old March 22nd, 2021, 06:22
Thanks for the answers guys, much appreciate your time. Turns out I was a dumbass on this one. I pulled the truck into the garage and gave it one more check over before dropping the tranny. The rear u-joint was now obviously shot. Maybe it was under load before and appeared tight, I don't know. Anyway, a new u-joint and a good greasing of the drive shaft slip joint, and the vibes were gone. Oh, the screeching sound? It's the blower motor! I'm beginning to think my Youtube mechanics' certification means s**t!
95 pilot bearing 1990xj OEM Tech Discussion 2 January 15th, 2011 07:21
input bearing or pilot bearing? purvisdotcom OEM Tech Discussion 8 January 4th, 2008 13:43
NEED HELP:Pilot bearing!!! AD-8 Modified Tech Discussion 1 March 13th, 2007 16:18
Throwout Bearing vs. Clutch Release Bearing xjguy98 OEM Tech Discussion 5 August 2nd, 2005 09:41
Vibes: Damaging t-case output bearing or pinion bearing xj92 Modified Tech Discussion 0 August 31st, 2004 11:33
