Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor Advertisements
Old May 15th, 2019, 13:36
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Exclamation New Product! Titanium 4.0L Manifold Stud Kit!
Another BWE exclusive!
Replace your OEM manifold bolts and cone washers with our high strength 6Al Titanium stud kit! We include 11 machined Titanium studs that are much stronger than the factory bolts that also provide much greater corrosion resistance. We also include new gold zinc plated 1144 high strength steel cone washers that are also much stronger than the OEM stamped steel washers. Then we top off the kit with high-strength and reusable Mil Spec lock nuts that will not loosen over time.
Benefits of our Ti Stud kit:
- Much stronger than the OEM hardware
- Provides even clamping pressure on the gasket
- Added corrosion resistance
- Easy installation (Studs have 5/32 machined hex)
- Will not loosen over time!*
Kit Includes:
11 - 6Al Titanium Studs
9 - 1144 steel cone washers
2 - Grd8 washers
11 - Mil Spec lock nuts
* You'll need to use some med strength thread-locker when installing the studs in the head.
$115 Shipped!
http://www.boostwerksengineering.com...Kit-_p_39.html
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old May 15th, 2019, 20:52
Anak's Avatar
Anak Anak is offline
Stranger
Re: New Product! Titanium 4.0L Manifold Stud Kit!
Ooh!
Hardware porn.
Talk about a lack of moderation...
I am tempted to order a set now just in hopes that I will have something cool before Cal has it.
Old May 16th, 2019, 14:19
lol. You should just to shove it in his face.
Old May 30th, 2020, 17:26
TRCM's Avatar
TRCM TRCM is offline
Hmm...add to the wish list
Old January 9th, 2021, 11:00
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
Any idea when you'll have them back in stock?
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 5" lift, SFR Long Arm, Deavers, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old January 10th, 2021, 23:21
maxbraketorque maxbraketorque is offline
How did you decide on Ti6Al4V?
Old January 26th, 2021, 13:02
side note for anyone looking to order. I ordered a set about 2 days after this, and got them on Monday.
John V.
RRC VP
Old February 4th, 2021, 22:32
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Originally Posted by Anak View Post
Ooh!
Hardware porn.
I never saw this post until now....
Old February 6th, 2021, 21:15
Anak's Avatar
Stranger
And I still haven't ordered a set.
Once my stroker starts moving forward I will need to think about these again.
Old February 8th, 2021, 10:34
cal's Avatar
cal cal is offline
Oh.
Well in that case I did beat you to them.
Old February 8th, 2021, 12:45
Anak's Avatar
Stranger
I squandered my opportunity.
Story of my life.
Old February 8th, 2021, 12:46
cal's Avatar
cal cal is offline
Well.
I can tell you this is a great product and i highly suggest it.
Old March 11th, 2021, 19:47
Calvin Bnvds Calvin Bnvds is offline
Well.
It seems like you are happy using this kit for the last couple of years.
Old March 13th, 2021, 08:48
I just installed them, definitely easier vs the factory bolts. And they look fancy.
The one thing I will say is if you're installing them on a head on the bench like I did, there's a couple studs you can't tighten all the way until the head is installed on the Jeep because the holes go through to the head bolts (at least they did on my 0331 TUPY head). But they were all easy to get to once the head was on.
John V.
RRC VP
Old May 21st, 2021, 09:24
tonytech tonytech is offline
Would love to see pictures of it installed.
Rate This Thread:
busted stud on the manifold Kejtar OEM Tech Discussion 31 June 15th, 2011 11:22
Exhaust manifold stud missing my2monkeys OEM Tech Discussion 1 September 6th, 2009 11:16
Exhaust Manifold Stud Replacement Questions Muad'Dib OEM Tech Discussion 73 July 31st, 2008 00:08
4.0 exhaust manifold stud Grand CJ OEM Tech Discussion 0 August 8th, 2005 04:55
exhaust manifold stud removal 2xtreme OEM Tech Discussion 3 February 21st, 2005 07:21
