Old December 6th, 2019, 16:29
Jeepmedic46's Avatar
Jeepmedic46 Jeepmedic46 is offline
Azzy’s design linkage
I was wondering if anyone has used the Azzy’s design linkage on their transfer case. My 2000 XJ transfer case linkage is broken and not able to find a replacement. It is a NP 231 Transfer case and the Jeep has a 4.5 Rough Country short arm lift.
Old December 6th, 2019, 16:41
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: Azzy’s design linkage
I have it on my 98. Wasn't impressed. It took me several tries to get it to work 1st of all, and then it bound up several times on the trail. I had trouble shifting back to 2 wheel drive. I would not buy it again.
If I were to do it over, I would look for a cable actuated shifter. Not that I think it had anything to do with bad trans mounts motor mount, my engine and trans was stable.
Praise Marty Moose!
Old December 6th, 2019, 16:42
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I've installed the boostwerks one a couple of times with good luck.
Old December 6th, 2019, 16:51
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Was just chatting about this on comancheclub. Between that and the Boostwerks they are the same really. The Azzys has some "graphics" and a high price tag.
88 MJ, 4.0, 4wd, 3 pedals, Shortbed.
Mods; ACOS, quick discos, HD tie rod and a bitchin air fresher
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old December 6th, 2019, 17:03
If I was going to go with a cable one which one would be a good one? I thought I saw on the Quadratec site they had one similar to the factory one.
Old December 6th, 2019, 17:27
denverd1's Avatar
denverd1 denverd1 is offline
Got Azzys on mine. Takes some adjustment to get installed correctly and some common sense when setting it up. Works great
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old December 6th, 2019, 18:32
I think I’ll go with the Azzy’s. I’ll have to try and find a place to install it. I can’t be on my back due to surgeries.
Old December 6th, 2019, 22:17
freggie freggie is offline
Have it installed, install was not bad but getting dirt in eyes was not fun. You can use a long screw driver instead of the pry bar and if you do not have a reciprocating saw, you can leave the oem brace thing on (I did, no problems).
The problem I had was fully understanding the directions for adjustment. I did not adjust it correctly and shifting was hard and popped out of 4lo. Carefully read the directions and it shifts butter smooth from 2hi to 4hi. Going between 4hi and 4 lo gets a little notchy but slides right in no problems.
Azzy's Design Works XJ Gauge Inserts Renegade_Azzy Vendor Advertisements 22 May 24th, 2013 16:10
Azzy's Design Works XJ Gauge Inserts - Carbon Fiber style for 89-96 XJs and MJs Renegade_Azzy Vendor Advertisements 0 January 26th, 2013 18:50
Need graphic design help Matt S. Non-Tech / Off Topic 5 March 18th, 2010 17:03
T-Shirt design Vince 25th Anniversary Celebration! Moab, Utah 27 November 9th, 2007 20:27
LCA lenght and design Xjdubber Modified Tech Discussion 0 April 8th, 2004 18:25
