Old May 15th, 2018, 19:31
TRCM's Avatar
TRCM TRCM is offline
Chassis on a rotisserie ??
I've been thinking (bad idea, right), has anyone put a cherokee on a rotisserie to work on the body ?
I have plans to:
1) put on front & mid stiffeners
2) patch some minor rust spots in the floorboards
3) install 2x6 rockers
4) upgrade the lift to the 5"-6" range, maybe even go with the new ironman 4 link front & rear (currently 4.5" mixed bag of parts type lift)
5) remove the factory roof rack, weld up holes and install custom roof rack w/drip rail mounts
6) modify the seat mounting points to lower the seat height
7) remove rear seat completely and replace with storage
8) replace front & rear axles
9) could also use a new exhaust manifold (easier to do with the engine out)
10) maybe replace rear main seal (not leaking , just weeping at this point)
11) rebuild t-case (chain & basic rebuild & put the magnet back in that I left out with the SYE install)
12) maybe install some flares, likely the Notch Custom brand
basically, perform the work in the sequence listed
My question is, if I strip the steering/suspension/trans/t-case/engine/interior/fuel tank to get as much weight off the chassis as possible, but leave the doors & hood/hatch on to help with the stiffness and then put it on a rotisserie and flip it to weld on the underside, will I have flex problems ??
Should the windshield be removed ?? I would think it would help with flex as well.
or should I tack the stiffeners on good before doing so ?
With all the work, I will be close to stripping it all the way down anyway, and I know for sure welding with it flipped will be easier than upside down, as long as it doesn't cause problems with flex in the body.
Thoughts ? Ideas ? Suggestions ?
Old May 15th, 2018, 20:46
BALTANAKT BALTANAKT is offline
Re: Chassis on a rotisserie ??
No clue. Maybe weld in some temp. cross braces?
Old May 16th, 2018, 05:15
old_man's Avatar
old_man old_man is offline
Not a great idea. The unibody will flex. Anything you fix may end up wrinkling when you take it off the rack.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old May 16th, 2018, 08:55
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
It's been done, and I've seen pics in the past, though it was used on a bare chassis. Years ago, AZRick had one for sale even, once he was done with it...
Throw "rotisserie" into search here, and you can follow some of the threads...
Member #133
Kleptomaniacs help themselves, because they can't help themselves......
Old May 16th, 2018, 09:20
TRCM's Avatar
I did last nite, and didn't see much of anything.......
Old May 16th, 2018, 09:43
RCP Phx RCP Phx is offline
You'll spend a ton of money/time just building the rotisserie!
Old May 16th, 2018, 09:45
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
It can be done. If you are worried about flexing you can easily tack some cross beams inside. Unless you're unibody is flaking apart I highly doubt it's just going to crumple being flipped on it's side. People use rotisseries on unibodys all the time, XJ isn't going to be any different.
Old May 16th, 2018, 11:32
TRCM's Avatar
May be...but I am pretty sure I can make one out of a couple of engine stands, some scrap metal, and a welder that will serve its purpose just fine.
Google chassis rotisserie and look at the images.....not a lot to it.
More worried about the potential of chassis flex while welding the stiffeners & rockers in upside down resulting in problems when back upright on the ground.
Since the interior will be out, I suppose I could tack in some cross bracing to mitigate flex, then remove the doors/hatch to lighten it even more.
Old May 18th, 2018, 09:16
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
rotisserie xj?
aren't you worried about it drying out? wouldn't an instapot be way better?
Old May 18th, 2018, 12:52
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
A rotisserie is a great way to work on a stripped chassis.
If you are worried about flexing when welding in the stiffeners and rockers, tack them in well, with the chassis level, and then rotate it for better access, to finish welding.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old May 18th, 2018, 13:13
TRCM's Avatar
rotisserie xj?
WTG Cal.........was waiting on either this or a "which spices did you use?" question........................
FS: 96 HO, 89 Renix, 95 chassis, 99 chassis jumpnjeep SoCal For Sale 12 July 19th, 2016 23:06
WTB: arc welder, rotisserie codyyy SoCal For Sale 0 October 4th, 2010 19:22
Chassis Baja_XJ JeepSpeed, Prerunner and Competition Tech Forum 17 July 5th, 2009 16:52
DFM's new Pro Mod Chassis AZXJ Arizona Chapter 1 September 1st, 2007 23:11
XJ rotisserie for sale AzRick For Sale: Private Party Only. XJ ITEMS ONLY 3 May 10th, 2004 17:16
