Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Tools and Garages
Tools and Garages This is a place to share about the tools and workspaces used to craft your latest masterpiece.
Old October 1st, 2018, 07:10
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Vise beefy enough for u joints, what do you have?
Hey all,
Looking for recommendations on a bench vise that's stout enough to press out u joints.
Any and all recommendations would be greatly appreciated.
Thank you
Old October 2nd, 2018, 09:42
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: View beefy enough for u joints, what do you have?
Instead of using a vise to remove and replace u-joints, I use an OTC ball joint kit.
It is easier if the driveshaft is clamped in a vise, to hold it still, while punching out the old caps.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old October 2nd, 2018, 15:00
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
I have the HF version. Definitely my go to for u joints. An impact driver for the screw and your done before you know it. A box end wrench or socket works fine too. On the plus side the case its in slips in the cargo area no problem.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
SoCal Chapter President
Old October 3rd, 2018, 19:26
Yeah I was trying to avoid not acquiring another tool that would hardly be used, the press is deffinetly easier.
Old October 8th, 2018, 01:38
markw's Avatar
markw markw is offline
web wheeler
If you own a jeep and if you wheel a jeep, you will use a ball joint press. Recommend OTC over the HF one. The HF one bends and breaks. Know two guys who have broken them. Make sure to get the 4wd adapters when you get it.
I also recommend one of these.
https://www.amazon.com/Macs-Tie-Down.../dp/B008PPNG2G
Mark Wolfe
N7YMW 95 Sport, locked and lifted.
Lakeside, CA
Old October 8th, 2018, 07:36
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter Treasurer
I used to use my vise for ujoints. But my wife got me this thing tiger tool 10105 ujoint puller. Its amazing and easy to use. About $100 on amazon but there are cheaper knockoffs as well. But mainly for removal.
I have this socket press for installation. Its a knockoff of the tiger tool one.
https://www.amazon.com/OEMTOOLS-2453.../dp/B07887QMNH
Rate This Thread:
1.5 shackles. Beefy XJRunner SoCal For Sale 13 October 26th, 2012 08:56
Beefy Wiser Modified Tech Discussion 8 February 8th, 2008 21:21
beefy u bolts djblade311 SoCal Chapter 44 July 17th, 2007 21:33
Project ramblings: knuckles, ball joints, brakes, t-case, side view mirrors RockTracXJ OEM Tech Discussion 2 March 26th, 2007 19:46
