Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter
SoCal Chapter The SoCal Chapter covers Southern California and Arizona. Please post local topics here.
  #16
Old July 10th, 2019, 11:36
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Re: Rock n Roll in CA
The crazy thing is I drove out to Pahrump on the 4th and felt the quake before I left Vegas.
Also, I thought Pahrump was in Nevada, not CA like that article says.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old July 10th, 2019, 11:38
dktool dktool is offline
https://www.sacbee.com/latest-news/8...ted%20(1).jpeg
Old July 10th, 2019, 12:53
David_Bricker's Avatar
David_Bricker David_Bricker is offline
PSR Fire Marshall
Location: Upstate NY-live; Death Valley-play; Hawaii-working on it
Article appears to be corrected - it says NV, near the Cali border.
Picture of Jeep - I would call a high lift jack and cinder blocks as "safely" lifted.
A shame it happened, for sure.
David Bricker / SYR - KOA
Gomer - '95 XJ, 2 dr. 4.6L Russ Pottenger Stroker; Novak TJ AX-15; Black Box 2.72:1 + 241OR 4:1; RockJock 60 Front, hydro assist, Hi-steer; D60 trussed and shaved rear; 4.56 ARB Front and Rear; Black Magic discs, Bilstein 7100s front and rear; 35s; PRP seats; Warn PowerPlant winch, hybrid cage. Annd, the Faux Dorkle is gone.
National Treasurer 2013-2021
Not a member? Become one today, and help support YOUR club.
Old July 10th, 2019, 12:57
Skwerly Skwerly is offline
The entire Jeep looks unsafe.
Old July 10th, 2019, 13:38
jcnoble's Avatar
jcnoble jcnoble is offline
Rock n Roll in CA
Are those his boots sticking out the front? Poor guy.
88 XJ Renix Patina Color
4:56 Gears
35" Tires
Long Arm y-Link
Old July 10th, 2019, 13:50
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
Look like rocks to me. In any event, a very bad way to go.
Old July 10th, 2019, 13:58
Looks to me like the entire blurred out part of the image is all his body fluid, likely a head shot from the axle / hub.
The 4x4 is suspect, was take a jack-stand that spit out ? The hi-lift was probably used to get him out.
Bottom line ........ a REAL F'ed up way to go.
Old July 10th, 2019, 14:04
I think those are rocks; body removed prior to snapshot.
Old July 10th, 2019, 17:55
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Originally Posted by dktool View Post
I've lost two friends over the years to falling cars. No earthquakes involved; just lazy enough for gravity to bite.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
SoCal Chapter Past President
Old July 10th, 2019, 22:58
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
I recall an earthquake at the shop one time, I had three cars racked...nearly shit myself...but none fell.
Praise Marty Moose!
Old July 12th, 2019, 11:29
Nimrod's Avatar
Degenerate Jeeper
A couple of years ago I bought some 12-ton jack stands from HF. The first time I used them they both collapsed as soon as I lowered the front axle of the Jeep onto them. I discovered that the pawls were cast steel, and VERY roughly cast. They just didn't have teeth to sufficiently engage the matching teeth on the riser. I took them back. About a year later I was hanging out at Avery's place when a HB 12-ton jack stand collapsed under Bricker's jeep, with Bricker sitting on the ground right next to it. Thankfully, no one was under it. BE WARNED -- I'VE PERSONALLY SEEN HARBOR FREIGHT 12-TON JACK STANDS FAIL TWICE. ITS A PIECE OF CRAP PRODUCT AND NOT WORTH THE RISK, in my opinion.
BTW, lest anyone think I just have some sort of axe to grind with HB, I have owed a set of their 6-ton stands for years and use them regularly.
Last edited by Nimrod; July 31st, 2019 at 07:23. Reason: Original post reported 6-ton stands were dangerous. I actually meant the 12-ton stands. My bad.
Old July 12th, 2019, 11:31
My new rule is HF stuff is OK in a pinch as long as there are no moving parts. I have no problem believing those suckers failed. When it comes to actual life-saving safety devices, spend the cash.
Old August 15th, 2019, 19:19
Nimrod's Avatar
Degenerate Jeeper
Originally Posted by JohnX View Post
Was at Dale Bros. Brewery seeing the Crown City Bombers play....almost didn't notice the quake until everything was swaying in unison.
Im heading up to Santa Ynez for the weekend. Gonna catch the CCB at a bar up there on Saturday night.
Old August 16th, 2019, 23:18
Bent's Avatar
Talking Re: Rock n Roll in CA
Why did I think you meant Bay City Rollers?
Old August 17th, 2019, 09:45
Nimrod's Avatar
Degenerate Jeeper
Um . . . I’ve got nothing.
Rate This Thread:
New IRON ROCK OFFROAD ROCK-LINK long arm set up NateColson89 Modified Tech Discussion 8 January 30th, 2018 15:56
Southern Rock Racing Series, Gray Rock stumpXJ South East Chapter 23 August 5th, 2013 08:59
eagle rock roll call/supllies list in4aride Colorado Chapter 24 September 19th, 2008 22:39
dana 30 locker/rock rails/rock lights needed Big Red Wanted: Private Party Only 1 March 18th, 2004 12:34
(NV) Draft EIS for the Black Rock Desert-High Rock Canyon Emigrant Trails... Ed A. Stevens Land Use Forum 1 March 20th, 2003 09:56
