Old November 6th, 2019, 17:29
Rainman's Avatar
Rainman Rainman is offline
alternator up grade- amps @ idle
looking to upgrade the 90 amp alternator. it realy struggles with the AC and the taurus fan in summer, thats with out the headlights.
to 136 or 160. there is $100 dollar difference, no junk yard options here.
At idle, or even 1500 rpm how much more is the 160 going to produce over the 136? Cause my understanding was the rated amprages were at higher RPMs.
Old November 6th, 2019, 17:48
ehall's Avatar
ehall ehall is offline
Re: alternator up grade- amps @ idle
What year is your XJ? The connector changed in 99 models. 98 and down can use the 136 amp from the ZJ and some Dodge/Ram, 99 and later can use the 160 amp from Dodge/Ram
my '91 beater rebuild
Old November 6th, 2019, 17:57
Rainman's Avatar
its 95 they have one in both amprages, same actual size that will fit with the 95 connector. No real junkyard options, been looking for about 4 years now for a 136, whicg were were supposed to get here........no luck so far, summer is comming.
Old November 7th, 2019, 06:48
techno1154's Avatar
techno1154 techno1154 is offline
You would benefit more from the larger case 160 AMP alternator if you could find one and get it to fit. They produce more voltage at low RPM which is what you really need. Some massaging of the brackets may be necessary.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old November 7th, 2019, 12:54
Rainman's Avatar
thanks that's what i was asking.
Old November 8th, 2019, 09:43
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
I think you may be able to add a smaller pully for some more juice to.
Old November 8th, 2019, 16:25
denverd1 denverd1 is offline
Fitment is the problem. I bought a Ram alt when mine shit the bed at Hidden Falls. Case wouldn't fit between the rail and the frame rail.
I probably need motor mounts but also have a small tcase drop so not sure where that leaves me in terms of more or less space between my rig and others. Just know that a 160 wouldn't fit
Old November 8th, 2019, 16:26
Like this idea on a stock alt
Old November 10th, 2019, 00:53
Rainman's Avatar
thanks all. Its RHD the alternator is up high where the A/c usualy goes- no frame rails. the brackets will need to be massaged as both the 136 and the 160 are the same size, but bigger than the stock 90 unit.
smaller pully is worth looking like.
Old November 10th, 2019, 08:38
MickeyS MickeyS is offline
please update this thread with what pulley you decide to use and which alternator you with if you decide to stray from 90amp.
thanks!
Old November 11th, 2019, 17:19
XJwonders XJwonders is offline
Huh, what?
Don’t forget to upgrade your cables when swapping the alternators out.
Old November 14th, 2019, 18:56
nblanton nblanton is offline
I put a Durango 160A out of a late 1990s or early 2000s into my 1995 without much issue. I had to grind the block and timing cover to get it to fit, but its in there without any issues. I'm running the late style belt arrangement due to intake and PS pump swap. I used the old pulley off my old 90A alternator without any issues. The plug is different, but you just get the plug that goes with the OBDII alternators to put them in a OBDI HO engine.
Ran 2ga wires with Blue Sea high amp fuses on everything and Mil-Spec battery terminals. No issues with power or dimming lights any more. I've got three Spal 10" fans on a Flex-a-Lite PWM fan controller. Stock voltmeter still dips and does weird shit, but I've stopped paying it attention at this point.
Old November 17th, 2019, 03:01
Rainman's Avatar
So went with the 160. was plug and play for the 95 loom., came with a pully that was same as the stock one. Already had the wiring upgrade.
its much hapier makes target voltage with taurus fan and aux fan running at idle, Ac as well.
Old November 17th, 2019, 03:04
Rainman's Avatar
Suuuper Low Idle: New Alternator? CherBear OEM Tech Discussion 3 July 26th, 2011 14:43
shackle bolt strength :grade-5 & grade-8 muddeprived Modified Tech Discussion 9 May 24th, 2010 22:59
Alternator Amps and electrical issues question sdigs OEM Tech Discussion 4 May 16th, 2010 13:15
big/little, grade 8/grade 5, look here for info bj-666 Modified Tech Discussion 2 August 2nd, 2005 17:32
OEM alternator output at idle? CaptTrev OEM Tech Discussion 1 January 24th, 2004 14:02
