Old August 5th, 2018, 17:41
notamechanic notamechanic is offline
Steering suggestions for 5.5-6" lift
Hey everyone,
I'm looking for some bullet proof steering suggestions for jumping up to around 6 inches of lift. What are some of your set ups. I'd like to know details, angles every part you have, what the easiest most cost effective solutions are and what the more complex solutions might be.. Keep in mind I have a budget of around $500 for steering.
I currently have zone's 4.5 lift with add a leafs. Kit involves 3" lift add a leaf with a 1.5" shackle. Planning on installing RE 4.5" full springs to net around 6" in the rear. I have a rock hard tire carrier so it should sit around 5.5/6".
Up front I have zones 4.5" coils, will be installing acos adjustable coil spacers to get 1.5-2 inches. Also will be running Iron rocks rock link long arm kit. Considering the clayton LA kit too, but feel a 3 link might be better than radius arms.
Heres the jeep on a fresh set of 35" km2's!
Old August 5th, 2018, 18:32
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Steering suggestions for 5.5-6" lift
Off Road only U-Turn steering, or the WJ knuckles steering and brake upgrade.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
RCP Phx RCP Phx is offline
Which are you trying to upgrade, the mechanical parts or the hydraulic parts?
Old August 5th, 2018, 22:03
Thanks for the reply. Both of those are a little over my budget. for the price Id definitely go for the WJ upgrade.Been putting some serious thought in the WJ swap, just seems a little complicated and pricey.
Right now just looking to upgrade the mechanical parts. Hydraulic parts will come later. Probably run a durango box.
Old August 6th, 2018, 06:26
I've been running a factory stock steering for 17yrs at 6" lift. I finally broke down last year and bought the Currie Correct-link. No change in the way it drives, just more confidence in the fact it's "Alot" beefier!
Old August 6th, 2018, 06:31
I will add that I'm running the WJ knuckles/brakes but I wasn't going to mess with making that style steering/trackbar to what already was a perfect set-up!
Old August 6th, 2018, 08:04
NCCherokee's Avatar
NCCherokee NCCherokee is offline
I am at about 5" lift, I did WJ swap last year, its pretty straight forward. Besides the brakes, it gives you two arms on the pass knuckle, so you can get rid of the inverted Y. I went with 1 ton ends, but some guys keep the WJ TREs which are still larger than the XJ stuff to save money.
I had Boostwerks send me the pieces he used to make his frame side trackbar bracket. of all the ones I could find, it outboarded the mounting point the most, given me the longest TB I could, short of putting the axle side on the knuckle, which would have required moving the coil buckets (which someone on naxja did do).
By lowering the frameside TB mount, and raising the axle size, I got *pretty* close to parallel with my draglink. I could get a raised pitman arm, but its close enough I haven't noticed any bumpsteer.
If you get a longer frameside TB mount, you WILL want to brace it to the opposite frame rail similar to RE. That extra leverage loosened up some of my bolts and I ended up with horrible death wobble. I'm currently in the process of fixing that.
I spent about $1000 on my WJ swap, but I had new rotors, new calipers/pads, ruffstuff 1 ton steering, JKS OTA trackbar mount, and the Boostwerks frame side. You can probably do it for a good bit less than that.
Old August 6th, 2018, 08:33
Rockwood Rockwood is offline
Anything going over the knuckle will need adjustment to the track bar angle.
I was thinking about this setup:
https://www.dirtboundoffroad.com/hig...-mj-tj-zj.html
Haven't seen much in the way of reviews on it.
Old August 6th, 2018, 13:16
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
WJ swap will be best overall but most expensive.
At $500 I'd go solid tie rod and stock with the rest. Still ahve enought $ to get a new track bar and some other gooides.
Currie makes a decent system but it's $$.
https://www.currieenterprises.com/ce-9701
Old August 7th, 2018, 13:26
sinat01's Avatar
sinat01 sinat01 is offline
Check out the synergy setup
Old August 8th, 2018, 22:59
Thanks for all the suggestions!
Really considering the currie set up. Only concern is its advertised for a 4" lift. Would this be okay at lifts above 4? would the steering angles too steep to run 6" of lift?
Old August 8th, 2018, 23:33
Einulfr Einulfr is offline
CavFab steering here; it's 1.5" solid bar instead of DOM. I'm somewhere between 6" ~ 6.5" of lift in the front and maybe 15 degrees on the angles.
Old August 9th, 2018, 07:41
I'm at 6" lift and all the angles are perfect w/ no bump steer. Like I said it rides/drives like a Cadillac!
Old August 9th, 2018, 20:25
sinat01's Avatar
instead of the Currie go synergy. similar setup, except you can replace all the ends, whereas the curry setup still has the draglink as one piece
Sent from my SM-G930P using Tapatalk
Look for 4" Lift Coils - Suggestions? 88JeepXJ Modified Tech Discussion 1 May 13th, 2010 07:41
3.5-4.5" Lift suggestions for a 97-01 eyesac Modified Tech Discussion 11 December 14th, 2007 08:28
Suggestions for basic 2" lift kit? Beast XJ01 Modified Tech Discussion 21 July 9th, 2007 18:36
X factory Steering on 8" lift...any suggestions? andrew2516 Modified Tech Discussion 17 January 31st, 2007 12:34
