Old January 12th, 2020, 19:57
Treleaven Treleaven is offline
Stumped with issues
Ill try to keep this simple
97 Cherokee 4.0 with AW4, NP242, snorkel, 33's, no transmission cooler
- few weeks ago, got stuck, used winch, ground on battery was crap and melted my ground terminal clamp. Replaced with nice new for both positive and negative
- week later the Jeep would start stalling once it got hot and not start for another 30 min. Happens when pushing through deep snow in 4lo. Checked cap and rotor and the rotor was garbage. Replaced both and no issues for a few weeks.
- today out wheeling, it happened again, and I lost overdrive on the way out of the bush
NSS is new. Tomorrow I'm going to check the TPS. Any other suggestions? I have a fairly new CPS I can install to test but not sure why I would have lost overdrive.
Is it related?
Old January 13th, 2020, 03:32
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Stumped with issues
May be related, maybe not. Find the OBD-II computer sensor that has become heat sensitive. CPS is a likely suspect.
Buy/install transmission cooler. Use Dexron_III/Mercon. Load Test Battery. Load Test alternator. Check fan belt condition and tension. Test fuel pressure.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old January 13th, 2020, 12:49
lawsoncl lawsoncl is offline
To clarify, by overdrive do you mean 4th gear or torque converter lockup?
Old January 16th, 2020, 11:59
CJR CJR is offline
In addition to the other suggestions. Since replacing the rotor helped, I suggest you get the ignition coil checked under load. The ignition coil may be slowly dying and not putting out enough voltage to the spark plugs under load. Forget continuity checks. If the internal coil windings are shorting out, the number of winding will be reduced (i.e. lower voltage to the plugs) but the continuity will be fine. Cracking of the coil's outer surface can also allow moisture to get into the coil.
Best regards,
CJR
Over Head Console Install Issues have me stumped?! Patriotsix OEM Tech Discussion 5 December 13th, 2016 10:41
AW4 Electrical issues have me stumped M50B06 OEM Tech Discussion 4 June 13th, 2012 19:45
willys issues hydraulic slave cylinder issues and dana 30 arb issues anyone got ideas blondejoncherokee Tow Rigs and Trailers 3 October 24th, 2011 14:49
Stumped pwt87mj Modified Tech Discussion 2 January 14th, 2011 11:01
stumped RICH2481 Tow Rigs and Trailers 6 November 3rd, 2005 05:21
