Old April 15th, 2018, 09:25
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Rear Fender Trim Write-up, retaining the stock flare (Fender Trim Part 2)
[QUOTE=Black1990jeep;246575958]That is great info. Does anyone know of a pdf of the front fender trimming by this gentleman? If it is half as good as the rear fender trim write up, it is worth its weight in gold.
Let me know if a front fender trim instruction is available, please.
/QUOTE]
Here you go, from the same source.
http://alum.wpi.edu/~kastein//Front1.pdf
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Front Fender Trim Write Up (Retaining the stock flare) 53guy Modified Tech Discussion 112 March 29th, 2014 12:47
Another Rear Fender Trim 88XJScott Modified Tech Discussion 7 November 12th, 2005 19:47
How much fender can i trim on my MJ? LazarusMJ Modified Tech Discussion 6 October 3rd, 2005 17:01
Fender trim turdles Modified Tech Discussion 1 October 25th, 2004 17:06
rear fender trim rooster Modified Tech Discussion 4 August 28th, 2003 10:00
