Old April 14th, 2018, 19:43
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Project Unicorn - a light duty trail rig
Which vibration are you referring to?
Old April 14th, 2018, 20:16
Weasel's Avatar
Weasel Weasel is offline
ah nix that, I had to go back and saw it was your old 2wd trans.
Just add lightness
Old April 14th, 2018, 20:20
cal's Avatar
cal cal is offline
Ah.
There was the 2wd trans, then there was the bent driveshaft, and the atlas rubbing the crossmember which i trimmed (SFR trans mount also fixes that).
No vibes in forever.
Old April 15th, 2018, 07:30
Anak's Avatar
Anak Anak is offline
Mostly Harmless
WRT that AFE intake, I assume you must be talking to someone there if you have been running a prototype, do you have any idea on whether or not they are applying to CARB for approval? If so, do you have any idea why they are cutting off at '97 rather than '96? Is someone at AFE not aware that '96 is also OBDII?
Old April 15th, 2018, 09:04
cal's Avatar
cal cal is offline
Interesting. Following up.
Old April 15th, 2018, 10:40
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
I like that intake.
Unfortunately that’s where my arb compressor is.
You think the gain is worth moving it?
John V.
Director at Large
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old April 15th, 2018, 11:10
cal's Avatar
cal cal is offline
I absolutely do.
TBH, I didn't notice when they added the intake to the car. I hadn't been driving it for a couple of weeks (travel) and then they had it for a week, returning it with the intake installed. I drove it for a couple of weeks, and then gave it back so they can do their dyno testing (after i'd put a couple thousand miles on the ecu and filter). Then I drove it for another 3 months with that intake.
Then smog testing came around and i swapped the factory intake back in (as they hadn't gotten the carb EO yet).
I certainly noticed that. It was like driving around towing a trailer. Sudden loss in acceleration, downshifting more, drop in fuel mileage. I like to be thorough about things, so i put a new wix factory air filter in, and no change.
I'd have told you 1-3 HP from an intake before this and been insistent about it. It was eye opening for me.
Old May 18th, 2018, 08:14
cal's Avatar
cal cal is offline
Production parts for aFe intake are in stock now. First ones off the line are already installed in my car.
Didn't even need to take a photo. Just hotlinking to their webpage. Probably should have washed under hood of my car before I let them take it.
https://afepower.com/afe-power-54-46...-intake-system
Old May 18th, 2018, 14:17
StinkyFab's Avatar
StinkyFab StinkyFab is offline
NAXJA Supporting Vendor
I really want this for the Lab Rat. Fingers crossed there will be a Renix version coming soon.
Dallas Ashley
WWW.STINKYFAB.COM
Motor Mounts, Fabrication tools, and Custom stuff for your Jeep!
Old May 18th, 2018, 16:19
Heavyopp Heavyopp is offline
What's inside the box?
Almost $400 shipped, sure would like to see why...
Old May 18th, 2018, 16:27
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
From the website:
Large 5-Layer Performance Air Filter:
This Momentum ST intake system was designed around the largest filter possible to allow maximum performance and filtration. This cone filter has a massive round flange and is 8" tall inverted top Pro 5R filter media. The Pro 5R performance air filter features 5-layers of progressively finer mesh cotton gauze oiled media and is constructed with 100% polyurethane frame for long life and multiple cleaning cycles.
Granted, a picture would be nice.
"Nothing is so invertebrate in nature as the worm of a lie that has been stepped on by the iron boot of truth." (Raezer v. Raezer, 428 Pa. 163, 166 (1968) (opinion by Justice Musmano).)
Old May 18th, 2018, 17:21
trippled trippled is offline
Sure looks nice. I don't care for their 5 layer filter as it's no different than a k and n but I have their dry flow filter. It works well and filters better. Have they changed their rubber material on the filter? It degrades a little fast for some reason. The elbow looks like silicone now which is better.
Did they release any Dyno results?
Old May 18th, 2018, 20:30
Kittrell's Avatar
Kittrell Kittrell is offline
This is awesome, a full high flow air box has always been a dream of mine.
Old May 21st, 2018, 16:52
cal's Avatar
cal cal is offline
Post 269 in this thread. One page back.
Old May 21st, 2018, 16:53
cal's Avatar
cal cal is offline
16 horses 19 torque to the ground, over the stock intake, on my car. They did text me the dyno chart, I can't find it now though.
New Project 89 XJ Unicorn zachxj01 North Atlantic Chapter 9 May 26th, 2016 16:39
Anyone use OME LIGHT DUTY leafs? djlarroc Modified Tech Discussion 19 August 10th, 2013 18:39
Project:Unicorn SAMSET Midwest Chapter 27 September 28th, 2012 10:58
WTB light duty truck tires XJwheelman NAC Classifieds 0 June 5th, 2011 14:41
Some light duty mods for a camping XJ terryd Modified Tech Discussion 10 January 11th, 2008 16:50
