On Board Air?
ILLXJ
Louisville, IL
Here are some pics. of the oba I set up this weekend.
I know I still need to install an oil/water separator. My ? is does any body run an anti-return valve inline. When I shut the XJ off the air bleeds back through the intake. Thanks. JIM.
Jim -
I use one in my setup. Keeps the system from bleeding down back through the pump. I got it from Kilby, but it's different from the one linked by Dirk.
Where's the retractable hose reel?:dunno:
you should be running either a checkvalve with an unloader port with a tube back to the cutoff switch if it has the option, if not get a load geneie unloader check valve that auto bleeds off, this way air does not go back thoug hthe intake and your compressor won't start under load as well
