Old June 13th, 2018, 12:17
Saudade's Avatar
Saudade Saudade is offline
Battery Voltage - Renix
Can one of you with a Renix and a full gauge cluster tell me what your dash voltmeter reads when the key is in RUN but you have not started the engine yet.
I'm having an intermittent sluggish start. I've cleaned both ends of my battery cables. Will get my starter and battery tested soon.
I noted that my dash voltmeter shows about 11v in Run but not started and almost 14 engine running with no accessories/lights on. I just never noticed it before. I measured at the battery and get 12.6 key off, 12.26 key on but not running, and over 14 running.
Thanks!
1988 Laredo 2wd Auto, AKA "Grey Ghost", 203K
Old June 13th, 2018, 15:37
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Re: Battery Voltage - Renix
What is the battery voltage (at the battery) during crank? Below 8.5-to 9V is a bad battery. 9-10V is weak. 10V up is ok. Bear in mind there is some fudge factor for ambient and engine temp. The dash guage isnt really the most accurate when the truck gets this old.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old June 13th, 2018, 16:03
Saudade's Avatar
Thanks, during cranking I get about 10.5V While doing this and the earlier measurements, I did not experience the "sluggishness".
I'll try "jumping it" at the starter relay, key off and see how it goes.
Old June 13th, 2018, 18:10
FlyNNN's Avatar
FlyNNN FlyNNN is offline
My 90' would struggle with this voltage. I just replaced my battery with an AGM and bought a "smart" charger. This pairing is the best combination this jeep has had in over 25 years. 12-13v during turn-over and over 14v during run. Response is perky. I have one of these plugged into the cigarette lighter socket to monitor;
https://www.ebay.ca/itm/12V-24V-LED-...AOSwDkVaaue v
Old June 14th, 2018, 10:14
Saudade's Avatar
So after a few more sluggish cranks, I just took it to my local Auto Center to test the battery. Tested bad. My 4th year on a 3 year battery. Case Closed.
Old June 14th, 2018, 14:50
four_shot's Avatar
How 'bout it Gonzo
Pehaps my math was bad then. Glad it was figured out.
4shot
Old June 14th, 2018, 15:46
Saudade's Avatar
Not so fast there. After a few more errands I had a sluggish start AGAIN (several)!! I saw the print out from the battery tester. It was not able to complete the recharge so it said "Replace Battery". It almost didn't start when leaving the parts store to get a replacement starter.
So I put in the new starter in and cranking it screams (in a good way). My old starter has a lifetime warranty so I should get a refund when I return the core. Good thing the starter is easy to replace.
So what the chance of both battery and starter being "bad"!!
Old June 15th, 2018, 12:25
four_shot's Avatar
How 'bout it Gonzo
It is quite possible. Low cranking voltage can cause excess heat in a starter and cause failure.
4shot
Old June 15th, 2018, 17:09
FlyNNN's Avatar
... or more likely a "going south" alternator not doing its job of charging the battery and the battery gradually being killed due to insufficient recharge.
Old June 16th, 2018, 09:01
Saudade's Avatar
I agree, quite possible. The "cranking speed" seems much higher than it's been in a while. But, I've also cleaned all contacts including starter mounting surfaces and the engine grounds.
Thanks for your input!!
Old June 16th, 2018, 09:04
Saudade's Avatar
I suspected that early on. Charging seems to be OK. I get ~14.5V engine running.
Still, I'll keep checking to be sure.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Afireinside
Renix Voltage Regulator Opp voltage spec? Ecomike OEM Tech Discussion 8 August 4th, 2017 20:06
Dead Battery-High Voltage bghrny OEM Tech Discussion 4 March 23rd, 2012 08:58
Battery voltage drops mountainbiker OEM Tech Discussion 4 March 12th, 2011 13:15
defroster and battery voltage...? MahnkenVille OEM Tech Discussion 2 March 31st, 2010 06:59
Battery voltage too low??? krelja OEM Tech Discussion 9 July 13th, 2007 05:41
