Old November 8th, 2018, 09:07
Spydie Spydie is offline
2000 T-case and trans in 1999 XJ HELP
Alright guys title says it all. I just bought a CLEAN Xj from Cali but the issue is its 2wd. I have a complete parts XJ to take all the 4x4 from (was my old jeep before it was rolled). Yes I know what I'm getting into, I just have a few questions in regards to the t-case connectors. Reading through some other write ups, they say the connectors changed from '99 to '00 and because of this you either have to change out the injector harness to a 4x4 harness or, from my understanding, 3 of the wires on the different connector are the same color, can i cut these 3 wires and put the '00 connector on the '99 harness? Again from what i understand the only thing this would eliminate is the indicator light for the 4wd. Any help would be appreciated!
1999 Cherokee Trans Fluid Everywhere Subzero OEM Tech Discussion 7 March 12th, 2017 16:34
1999 vs. 2000 poomero OEM Tech Discussion 3 February 10th, 2016 14:33
WTB: 1991-1999 4.0L - Auto Trans alohajeff SoCal For Sale 6 February 11th, 2014 23:23
1999 standard trans swap into 2000 auto xjhunter81 Modified Tech Discussion 0 May 30th, 2013 22:35
2000 vs 1999 & Pre UCA? Monkey55 OEM Tech Discussion 5 May 22nd, 2009 23:58
