Roanoke XJ
- Roanoke, VA
Has anyone ever used a Dana 44 with Vacuum Disco? What problems did you run into? Is it worth building, i.e., replacing shafts, hubs, etc...
, but couldn't tell you if its worth it.just got a non-disco axle shaft at a pull a part and it fit, and where the shift mechanism is on the cover i used a nut and bolt on the front one to close that hole and a brass fitting w/ a nut on the inside to connect a breather hose to, nothing to it
Roanoke XJ said:I thought the vacuum is on the passenger side, therefore, it wouldn't matter about the driver side. Isn't the driver side already a "one" piece axle
and driver's side inner axle shaft. I'm pretty sure this is doable, don't come hunting me down if it doesn't workRoanoke XJ said:That would make sense! So if I swap out the ring, pinion, and carrier, then I shouldn't have a problem? How does the pumkin diso work???
mad maXJ said:and driver's side inner axle shaft. I'm pretty sure this is doable, don't come hunting me down if it doesn't work
