Old March 14th, 2019, 21:51
tech1001 tech1001 is offline
big valve head
Has any body used the head with bigger valves and did you gain any more power and about how much do you think it was and are you happy with the head ? Odessa Cylinder Head sells one with a 2.02 intake valve and 1.62 exhaust valve , I would all so clean up the ports . thank you for any info you can give me .
Old March 14th, 2019, 22:35
RCP Phx RCP Phx is offline
Re: big valve head
I run one of Russ's LS1 valve heads but it's fully ported and on a stroker. The intake is ported and bored for a 62mm throttle body. What else on the motor do have you done?
Old March 15th, 2019, 07:52
denverd1 denverd1 is offline
Re: big valve head
stock head flows pretty good. if you haven't done intake/exhaust, I'd start there.
if I were to do a big valve head, I'd definitely move to a bigger lift/duration cam to take advantage of those valves. so make sure you have springs on the head to handle such a cam if that's of interest.
Old March 15th, 2019, 10:20
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: big valve head
Yeah going big valve isn't going to matter without a port and polish, and a cam. That becomes a whole thing.
Old March 16th, 2019, 01:57
Re: big valve head
I did want to clean up the ports and run a set of roller rockers , I'm not looking for a lot .
Old March 16th, 2019, 07:38
Re: big valve head
For 50yrs I've told my customers "you can't get it in, until you get it out".
Old March 18th, 2019, 02:54
Re: big valve head
I did forget to say that the head on my jeep now is cracked so I will be buying a replacement head , I just don't know witch one yet .
Old March 18th, 2019, 18:53
Re: big valve head
I hate saying like this , What are you trying to say?
Old March 18th, 2019, 22:44
Re: big valve head
"You've got to get the exhaust charge out before you can get intake gasses in"
Old March 19th, 2019, 10:44
Re: big valve head
thank you cam, exhaust valve and compression stroke?
should he run bigger exhaust valves than intake? longer exhaust duration? turbocharge it?
Cylinder head valve... Paintballpsyco2369 Modified Tech Discussion 9 June 26th, 2012 10:55
will ho valve cover fit renix head? H8PVMT OEM Tech Discussion 6 March 14th, 2012 10:21
Renix valve cover on a HO head? MoFo Modified Tech Discussion 2 April 18th, 2010 20:44
Valve Cover Leak Due to Head? drew_man_chu OEM Tech Discussion 6 November 12th, 2008 16:29
Do I need a valve job or any head work? jeepboy381 Jeep Street and Performance 8 February 18th, 2008 21:41
