Old August 1st, 2020, 20:18
Apexi13b Apexi13b is offline
XJ Heavy Steering
Hey everyone, I just picked up a 2000 Cherokee Classic with 170k miles a couple of months ago. I've been doing some preventive maintenance and get all the little things fixed. So far I have Replaced the factory steering damper, replaced all four tires and gotten an alignment, and had a fellow mechanic look at the steering. We still don't know why but the steering feels heavy. It feels as if the wheels are flat when you steer. Steering pump sounds strong could it be the steering box? Any ideas would be greatly appreciated.
I have done a search on it but couldn't find anything relevant.
On another note first post looking forward to hearing from people on this forum.
Old August 2nd, 2020, 06:51
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: XJ Heavy Steering
Heavy steering compared to what other vehicles ? You have to remember you are driving a shining example of 1980's AMC automotive technology with a solid front axle.
Originally Posted by bimmerjeeper
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old August 2nd, 2020, 14:39
b00001 b00001 is offline
I will take "heavy" steering vs sloppy, loose steering any day. Might just be how it feels to you vs newer vehicles. Have you swapped out the pwr steering fluid? That is an often neglected fluid and it can make a difference with some new juice.
Old August 2nd, 2020, 14:49
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Maybe check the tow-in on your alignment, some shops don't know 4wd vehicles.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old August 2nd, 2020, 18:00
8Mud's Avatar
8Mud 8Mud is offline
Could be somebody fiddled with the center over adjustment on your steering box. If they did it is likely they left some wrench marks on the locking nut.
Old August 3rd, 2020, 02:41
I have not replaced the power steering fluid I will have to check the paperwork for my alignment.
Tomorrow I will get under the car and check the steering box.
My friend has a 2001 Cherokee and his steering feels a bit lighter and smoother. Thats the only one that Im basing it off of. I did notice today that the steering wheel sometimes does not return to center as well.
Thanks for the help I will check all of it out
Old August 3rd, 2020, 03:53
Tim_MN's Avatar
With the additional info, I would suspect the ball joints and would wonder what the alignment numbers look like.
Old August 3rd, 2020, 04:28
75SV1 75SV1 is offline
I've had a new steering stabilizer stiffen up the steering feel. Either I got use to it, or it loosened up after a while.
Heavy Steering nrwphoto OEM Tech Discussion 7 September 8th, 2019 19:43
CURRIE STEERING ON SALE $150 OFF - CURRECTLYNC - TJ/LJ/XJ/MJ HEAVY DUTY STEERING KIT RWKHausSupply Vendor's Specials 0 August 30th, 2017 10:32
Heavy steering Waynerd OEM Tech Discussion 3 September 4th, 2016 09:38
WTB: PSC heavy duty steering box 1998xj1985 SoCal For Sale 3 January 21st, 2008 17:25
Heavy Duty Steering ARTSTER Modified Tech Discussion 13 November 17th, 2003 16:29
