It seems like most who do shock hoops brace them against each other, at least, and that will change the loading, at least. The torsion on the frame rail should be reduced on straight compression, and on flex the torsion would split across both sides. Also, even a drooped coilover will be putting some force back into the tower, until the tire is floating.
How long are your control arms? Or, how much horizontal movement does the shock body have at the point where it exits the box? One advantage to a more open tower would be more room for the shock body to move, which would help in a rig with horrible short arms and a short panhard. Of course, a well set up rig with longer arms and a long, level panhard will have less horizontal movement in the shock body during travel.
