2000 XJ... stock. 94kish miles
running fine, let it sit for 2-3 hours and wouldnt start. Engine turns, no fuel. Shot some starting fluid in there, and tried to start (only from the fluid)
There is gas in it.
Heres my question. The fuel gauge doesnt work either... looking at a helms manuel, the fuel pump and float are the same assembly? so this makes sence, right. The fuel pump just shit the bed?
Also, my fuel pump is on top of the tank. Can you access it from inside the vehical (is there an access panel in the trunk area?) or do you have to pull the tank.
and how long does this take... to change the pump. can I do it away from my garage? or should I tow it home.
and last question... Thought maybe I blew a fuse.. where is it located? I checked pretty much every fuse in the pass. footwell and under the hood and couldnt find a blown one. I even switched out the fuel pump relay.
Please help!
There is gas in it.
Please help!
