Old November 19th, 2018, 10:47
92xjRJ 92xjRJ is offline
Re: 93 XJ BUILD (WITH LS SWAP)
Was painting the headers last night and went to shoot some of the white paint and the can was just spraying speckles, so I just said oh well and went with It... I was going for a red, white and blue theme.. Also got some ICT brackets in for power steering and alternator relocation. if things go as planned ill have it dropped in over the holiday weekend and be running all my fuel and brake lines.
I haven't put the alternator on yet but that will hopefully be today.
Old November 19th, 2018, 19:52
Got the alternator mounted up, i like it, sits pretty low. I may eventually go with an LS1 style intake but for cost right now I'm just going to chop the hood up little and do a cowl hopefully it comes out ok.
Old November 24th, 2018, 14:05
ftwelder's Avatar
ftwelder ftwelder is offline
Damn this looks good. Thanks for the updates.
endless jeep project that will eventually end up as a rust bucket in someones backyard.
Old November 24th, 2018, 15:24
Thanks! It's been a very long road. Still have to pull the trigger on a trans and picking up a t-case on my trip upstate mid December.
Old November 24th, 2018, 15:32
I got some time to drop the motor in today so I could get some ideas for running all my lines..
Old November 26th, 2018, 09:38
Just shopping around online for a track bar set up and am wanting one with the cross brace, anyone have experience with using one with an ls swap?
Old November 26th, 2018, 13:33
I think im just going to pick up the IRO track bar set up, I had it on my old xj, it was beefy and its on sale right now for 129 with the bracket.
Old November 26th, 2018, 16:01
so I dropped the motor in with the L59 oil pan and I definitely see what you guys were saying about the clearance. I am looking into a hummer H3 alpha oil pan, the sump is about 13inches back, lm5 is between 12.5 and 12.75 back so I figure why not take that extra 1/4 inch. Any one else hear anything about this oil pan?
Old November 28th, 2018, 08:30
Got started on the hood a little bit yesterday in some down time, I need to get some sheet metal and a welder down to my shop ( damn place doesn't have provisions for my 220v so I am trying to piece my old 110 back together lol)
Old November 28th, 2018, 14:21
More of the hood, I need to get something to use as supports im thinking just some small pieces of solid stock, then once I get the contour I want ill cut some sheet metal for the sides.
Old December 2nd, 2018, 08:07
Tacked in some rod on the hood to get the contour for the cowl. Now just have top get some sheet metal for the sides and fill her in.
Old December 5th, 2018, 10:47
alternator and ps pump mounted in the bay for line measurements and connector relocation
93 XJ BUILD (WITH LS SWAP) 92xjRJ Modified Tech Discussion 0 May 5th, 2017 11:21
88 MJ Build / Axle Swap with Q's laxbro37 Jeep Comanche MJ (1985 - 1992) 3 January 31st, 2017 06:35
XJ 5.3 swap (build) blistovmhz Modified Tech Discussion 4 March 19th, 2016 18:26
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 20:26
Santa's tear-down/swap/build-up juryrigjalopy SoCal Chapter 80 August 10th, 2007 15:35
