Toyman
- Western Canada
I have a 99 XJ 4.0L and I have just replaced the water pump with a reman'd unit in late Oct 06.
In the last 4 days, I have noticed that there has been a leak, coolant dripping from the front of the engine and I have not been able to locate the exact source of the leak. I have seen that coolant is coming from somewhere around the bottom of the water pump, it flows down the bottom of the lower rad hose and drips down to the ground from there.
Now, this leak only happens when the engine warms up and the system is pressured up. If I start the engine and let it idle, there is no leak. If I drive around for a few minutes, the leak starts again.
I pulled off the lower rad hose and I can see no stresses in the hose. I put in a new hose anyway, at 336,XXXkm, what would be the harm.
The water pump should be fine, considering it is only 5 months old, but parts have been know to be defective. I assume that if the water pump was gone, then coolant should leak out of the weeping hole upon starting up the engine before it gets pressured up, am I right, or I am wrong? Let me know your thoughts and experiences...
