OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
All Gauges keep going dead, then airbag light comes on
Ok guys need some help. My Instrument cluster keeps going completely dead. Then the airbag light comes on. Doesn't seem to affect anything else. If you shut the Jeep off everything will start working again. I started cleaning grounds today. Any advice?
#2
Re: All Gauges keep going dead, then airbag light comes on
what year?
could be a bad connection at the back of the cluster. common problem. |
#3
Im sorry, it's a 98'. Does the airbag light typically come on with a loose connection like that? Friday I'll pull the cluster and check it out. Any other suggestions?
#4
my 01 Sport does the same thing. Usually pressing on the guage face brings it back, i need to pull it off and check the connections.
#5
Does your airbag light come on when it does it?
#6
Yeah exact same thing..
#7
k, thanks
#8
Pull the instrument panel. Clean the contacts, use some dielectric grease, and see if you can pull on the harness and get a little extra "slack" back there to take the strain off the connector.
#9
My 98 is doing the same thing....I already pulled the cluster out once but I didn't clean or lube anything, which hopefully will take care of the problem, I'll try it this weekend!
#10
I have owned my '98 since new in '97 and have had that problem since '00. The dealer has performed their TSB where they remove the bus connectors that snap into the instrument cluster and replace them; which only lasted for several months. I personally have removed the instrument cluster at least 6 times to clean the terminals. A friend of mine that is a Jeep Tech at a local dealership tried what usually works for him at the dealer; that only worked for 2 months. About 2 years ago I cleaned the cluster pins and connector contacts with contact cleaner and scotch bright and then applied dielectric grease; the problem returned after a week. Nothing has solved the problem; so I just live with it.... Pressing on the cluster face almost never worked for me; what does work everytime is flipping the turn signal lever upward to make a right turn. The airbag light goes away and the all the instrument cluster functions resume. |
#11
But thanx guy's on the infor I will pull them out asap and check things. |
#12
Thanks for the advice! I've been having the same problem since I've had the Jeep for two weeks. My problems seems to be related to the overhead console buttons being pressed - does this seem possible? I'll try the suggestions.
#13
I have a 98 with the same problem. Usually pushing on the face of the gauge cluster works for me. I read a few months ago in either JP mag or 4wheel offroad that there's a replacement harness available that's supposed to fix this but now I can't find any info on it. The article listed the part number but now I can't find it. Does anyone have it?
#14
Probably 9 years ago there was a Technical Service Bulletin issued addressing this problem and I had the new buss connectors installed under warranty. This is where they cut the old connectors off the harness and solder new ones onto the existing wiring. That procedure only lasted about 6 months and the problems returned. The problem stems from oxidation on the contact surfaces of the instrument cluster pins and the buss connector surfaces. In the 13 years that I have owned the Jeep; I have removed the cluster over a dozen times cleaning the contact surfaces and the problem returns. Several years ago I actually cleaned the surfaces with Scotchbrite, wiped the metal with plastic safe contact cleaner and the applied dielectric grease to the connectors and pins. The problem returned within a couple months. Now I just deal with it....where I move the directional stalk to make a right turn and the gauge function returns..... |
#15
I have a '93 and a '98 XJ and the gauges on BOTH cars go dead every now & then.
I've done nearly everything (cleaned up grounds, pulled and cleaned the connectors and reassembled with dielectric grease) and the results are either short-lived or no improvement at all. On the '98, pressing the gauge pack into the dash works, albeit temporarily. On the '93, thumping or tapping on the gauge pack lens will sometimes cause the tach and speedo needles to spring to life for a few miles. The only thing I haven't done is to cut off and replace the harness connector. I WAS going to do this, but now I've read here that this, also, effects only temporary improvement. Up until now, I thought Lucas electrics was bad (the Lord Of Darkness; the bane of British sports cars, etc.) ...but now...I'm beginning to think Chrysler may have kept the spirit of problematic car electrics alive and well. |
Thread Tools | |
Display Modes | |
guages die when airbag light comes on, wtf? check engine light on | rockhard4x4 | OEM Tech Discussion | 9 | June 20th, 2009 06:34 |
all dash gauges are dead all of a sudden, help | RWKHausSupply | OEM Tech Discussion | 8 | August 17th, 2008 10:51 |
gauges dead | CBB311 | OEM Tech Discussion | 4 | April 7th, 2008 11:27 |
01 gauges and check gauges light | Ramsey | OEM Tech Discussion | 2 | October 6th, 2004 23:01 |
Lights dead in gauges and console... | sportsguy | Modified Tech Discussion | 12 | June 16th, 2004 05:20 |
