Old October 13th, 2018, 09:13
Wolperdinger Wolperdinger is offline
Question Ford 8.8 - Weld Tubes or Not?
I'm going to put an 8.8 in my 91XJ. It looks like there's two dedicated schools of thought on whether or not to weld the axle tubes to the pumpkin. Some say do it, some say don't because it will create a stress point at the weld that is more likely to fracture. I'm going to weld an Iron Rock truss on to the axle as well, if that make a difference. Thoughts?
Old October 13th, 2018, 11:42
Jim Malcolm Jim Malcolm is offline
Re: Ford 8.8 - Weld Tubes or Not?
A U-Channel truss like that won't do much to resist spinning a tube, which is why you weld them to the housing. It doesn't need to be an all around weld to serve the purpose of resisting tube twist. 4x 1" welds spaced 90 apart would be sufficient. Mine's fully welded all around without a truss, but a guy I work with builds rears for full body drag cars and charged me way to little, so it was a no-brainer for a "grinder" like me. Just make sure you do it right; high nickle wire or rod, pre and post heat, controlled cooling, preferably tig, but mig turned up hot can work if you know what you're doing. Often times you can hack it and it never becomes and issue. You'll be hard pressed to break it with a 4.0, unless it's a complete bind in the rocks while hammering on it in 4 low, and at that point the shock axle shaft would probably still be the weak link. The issue with the 8.8 is that the "plugs" are just welds to the unmolested tube. In other axles, it's a pin that's pressed into holes in both. Obviously better at resisting twist.
Old October 13th, 2018, 12:29
I thought about doing that, too. I don't know if anyone else has tried it.
Old October 14th, 2018, 00:28
trippled trippled is offline
I just mig welded mine to be safe. No pre or post heat, covered it with a welding blanket to be safe. Going on a few years now and still all good. Just make sure you clean it as best you can.
Old October 14th, 2018, 08:35
That's good to know, thanks. Might as well do it rather than regret it later on the trails. I think the truss will help prevent any possible tube fractures.
Old October 14th, 2018, 12:57
denverd1's Avatar
denverd1 denverd1 is offline
do it. cheap insurance. I didn't realize just few inches of weld was enough, i'll be welding the tubes on the 44s when they go in
single bead on it or should I make a few passes? seems like a big joint to just lay down a single bead
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old October 19th, 2018, 10:01
freerider15's Avatar
freerider15 freerider15 is offline
I would weld the tubes (will be on mine).
Just make sure to do it in stages. That much heat in a small time frame has a recipe for out of alignment axle tubes.
XJ Buggy On Tons
Old October 19th, 2018, 10:04
denverd1's Avatar
1" bead at a time, then rotate to opposite side?
I've read Danas don't need to be pre-heated or slow cooled, not sure about 8.8
Chili Pepper '98
Old October 19th, 2018, 10:19
I can't remember what the center section material is.
But put it this way, it's never wrong to pre and post heat (as long as you don't hit higher temperatures to where the materials properties start changing).
I'll be doing my D60 tubes in a manner of 6 hard tack welds, and welding opposite sections in between the tacks.
Then for the full burn in on second pass, I'll go around the entire thing back jump welding or whatever it's called (You jump back, and weld towards the bead you just laid down) to minimize overheating.
XJ Buggy On Tons
Old October 19th, 2018, 10:21
denverd1's Avatar
ok. thx, I'll grab an IR thermometer and hit it with a torch
Chili Pepper '98
Old October 20th, 2018, 19:00
Mach2nh Mach2nh is offline
I weld all axle tubes. Why risk it.
anyone weld d30 inner C's onto a ford 9" blondejoncherokee Modified Tech Discussion 12 March 24th, 2011 00:06
RE mono tubes $50 Swamprat Red River Chapter For Sale/Wanted 0 April 29th, 2009 16:31
preping the axle to weld tubes to the housing??? Hammered Modified Tech Discussion 8 September 5th, 2008 09:23
Ford 8.8 axle tubes,.. bxj Modified Tech Discussion 5 August 11th, 2006 16:28
MPG down the tubes... JeepXJ93 OEM Tech Discussion 19 January 26th, 2005 20:15
