Dirt101
- Lincoln, NE
Im getting some bumpsteer and wondered how the geometry looked on my steering..I bought the jeep just how it is, its at 4.5" with an adj trackbar ...any thoughts or advice? Thanks
passxj said:Put the trackbar back in the original axle side mount.
Dirt101 said:I wondered about this..should I not have the drop mount w the adj bar?
Pro-comp and Rough Countrylowrange2 said:I wonder who makes that bracket. Mine had that same bracket on it when I got my Jeep and I recently removed it and wondered who made it.
RCP Phx said:Pro-comp and Rough Country
I have had one floating around for years,use it whenever I get a CAB,but I always get it back later after they figure out it sucks!lowrange2 said:I was thinking RC... good to know - I don't know why but yeah - good to know.
bump steer occurring with both wheels hitting a dip or bump simultaneously is the result of steering geometry design issues.Dirt101 said:Its not the steering wheel shake, my TJ did that a little bit...its usually when hitting something at an angle or with just one wheel, honestly its not bad at all and Ive driven it for a few months already but just got to looking and figured if taking the bracket off will put the TB and DL in line then why not.
Djjordache said:put it back in the stock spot the trackbar and drag link are supposed to be parallel see pic:
MaXJohnson said:It looks like your yellow line(relocated) doesn't terminate at the original track bar axle mount. If you were to redraw the line more accurately, the yellow and red lines would still not be parallel and you would lose some track bar length compared to the current setup. The net result would be slightly closer to parallel than the current setup at the expense of a greater difference in length. Probably a wash.
yeh, I think you're right, although I still think the control arm angle is the bigger culprit herelowrange2 said:No I'd say it terminates dead on the factory tracbar bracket... I believe you're looking at the wrong bolt.
