Cruzzin_XJ
- CO
I've got a weird problem,
I have a 98 XJ 4.0 Auto, i drive every day 15 miles each way back and forth to work, it works flawlessly on a daily basis. The weird thing is that when i take it on a trip like today heading 90 miles to the Colorado Chapter Quarterly Meeting in Colorado Spings, i had problems on my way down. The drive is a tough drive on the XJ. My engine is running at 2800 to 4000 Rpm trying to stay up with the 75 mph speed limit which in reality is 80 to 85 on I-25 south. The tranny is cycling in and out of overdrive trying to haul my 35" MTRs, and pushing the 4.56 gears. My problem is that under this load the XJ starts to smoke out the rear, i pull over and and take a look. The inspection cover is leaking very badly about 3 to 4 ounces of oil drains out. This has happened to me 4 months ago and I replaced the Rear Main Seal and Oil Pan Gasket and it has worked well for the last 4 months. One thing i never understood is that the Oil Level in the motor increased the last time it happened . Again today i check my oil level expecting it to be low from the leak oil on the ground and all over the XJ and it's about a quart high and very thin. This is very strage because i just changed the oil 2 weeks ago and only put in 4 3/4 quarts. I know for a fact that the extra oil is comming from somewhere, but not sure where. It doesn't look like Anti Freeze, but could be Gas? I'm really Baffled.
Can anyone help me with this
John
John
