Old October 21st, 2003, 09:33
rws rws is offline
DANA 44 Trak Lok
I have a dana 44 with a trak lok diff. Does anybody know how to tell if the trak loc is worn out. I have raised the rear end and spun the tires and they both spin in the same direction. I do minor amounts of off-roading and do not want to put a locker in.
Old October 21st, 2003, 09:56
woody's Avatar
woody woody is offline
Gone but not forgotten...
That is the accepted way of determining it is functioning. If the wheels spin in opposite directions, it's toasted (or an open diff) another way is to find a slick (safe) area and breifly nail it in low gear... you should see evidence of both wheels spinning.
In some places it may take a little brake pedal applied to get both back wheels to grab. zSince you don't want to go in deeper, I'd advise to stick with what you have in there, and have fun!
[CENTER]
[/CENTER]
Old October 21st, 2003, 10:13
GPRSDLYT GPRSDLYT is offline
do trac loks act like posis?
Old October 21st, 2003, 10:49
woody's Avatar
"do trac loks act like posis?"
When they are functioning they do, or so I'm told. I haven't & don't plan to wheel the D35 one in my 88, so I have no personal feedback...other than both back tires spin on sand & wet surfaces.
The Trac Lok is Jeep's factory offering for the XJ & TJ (ZJ?) it's a clutch driven limited slip.
Many folks have pointed out that these get ineffective (or will wear out the clutches sooner) with larger or grippier tires.
I personally wouldn't go out of my way to put or keep one in a trail rig, but for a mostly street &/or mild trail rig a working one is better than open imho.
[CENTER]
[/CENTER]
Old October 21st, 2003, 11:03
rws rws is offline
Trak-lok is Dana's version of posi-trak or limited slip diff. In the dana the clutch packs are not hard to replace however they are expensive and it is a time consuming process. I was hoping that there was some sort of sure-fire method to test how worn they are other then taking the carrier apart and looking at them. The manual says nothing about testing. What a great forum this is!
Old October 21st, 2003, 11:39
woody's Avatar
These also need additive in the gear oil
A liquid 'friction modifier' sort of stuff.
Small one-shot bottles of this can be found at the parts counter at any Jeep dealer & simply add it when refilling the gear oil.
[CENTER]
[/CENTER]
Old October 21st, 2003, 12:17
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Somewhere there is a torque spec for checking clutch type limited slips. It was easy on the old AMC cars because the two-piece rear axles had a nut on the outer end of the axle and you could put a torque wrench on that.
With an XJ, you would have to make up an adapter to bolt onto the hub, with a 3/4" nut welded in the center, on axis with the axle. Then use a torque wrench to try to spin the axle with the opposite wheel on the ground. The accaptable number was surprisingly low, IIRC, something like 25 lb-ft. If it broke free at less than that it was deemed to be worn out.
Those numbers were posted some time ago -- don't know if a search would turn up the thread.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old October 21st, 2003, 13:37
rws rws is offline
Thanks. I'll give it a try.
Old October 21st, 2003, 14:24
OILBURNER OILBURNER is offline
Re: These also need additive in the gear oil
Also, aren't ya supposed to change the diff fluid & additive like every 3rd oil change or something like that?
dana 30 dana 44 and misc jeep parts cheroking For Sale: Private Party Only. XJ ITEMS ONLY 23 February 25th, 2004 15:15
XJ Dana 44 CartsXJ For Sale: Private Party Only. XJ ITEMS ONLY 1 December 16th, 2003 07:54
WTB front dana 30 diff guard for 90 xj in CA lapaul Wanted: Private Party Only 2 December 11th, 2003 13:27
Trak Lok Installation woodrock03 OEM Tech Discussion 5 October 15th, 2003 16:06
Dutchman Shafts are junk...... PeterBuilt North Atlantic Chapter 4 September 4th, 2002 06:28
