Old September 25th, 2021, 16:42
truckeejeeper's Avatar
truckeejeeper truckeejeeper is offline
Battery drain after steering pump replacement
Hi y'all. So I had my steering pump replaced at my local shop, and when I picked it up, the guy had to jump it in the shop. Hmm..Ok, whatever. I get it home. Next time I go to drive it (3 days later) my battery is bricked. Like reading .5v. Can only get it to charge back up to 12.4v. It's a 6 year old Odyssey AGM, nvr had an issue with it, ever. Ok... So I head to oreillys and throw in a brand new Super Start AGM. Drive home and park. Get in to drive it 3 days later, dead as a rock. No click, turnover, nothing.
I can only assume that something happened during this pump install that is now draining my battery. Although I can't imagine how that would affect any electrical stuff. Of course I'm going back to the shop next week (sadly I don't have a garage and have to park on the street) but I like to be armed with information.
Any help appreciated. Thanks y'all-
1991 Sport 5speed - All Stock
Old September 25th, 2021, 19:38
RCP Phx RCP Phx is online now
Re: Battery drain after steering pump replacement
That's a tough one since there is almost no electrical in the area let alone something that could cause a drain. The fan is about the thing in the area that could possibly cause a drain. I would suggest you put a ammeter on it and how much draw your pulling.
Old September 26th, 2021, 00:01
8Mud's Avatar
8Mud 8Mud is offline
Coolant increases the conductivity of water and stays moist much like salt from humidity. Try hosing down your alternator.
Side story I once had a pinhole radiator leak that sprayed coolant on the battery. I was chasing down a power drain and got my ear close to the battery, it was really faint but the battery draining to ground through the coolant film sounded like frying bacon. IMO if can happen on the battery it can happen in other places, like the alternator or even any other path to ground. Hot water works better than cool water, just be careful what you are spraying and let it dry out some before running.
Old September 26th, 2021, 00:05
8Mud's Avatar
Could be the front harness where it goes down the front of the motor. If it is routed wrong it can cook on the exhaust. fairly common to accidentally reroute it when working in that area. Though the harness only has power with the key on?
Out of ideas.
Old September 26th, 2021, 08:29
Saudade's Avatar
Saudade Saudade is offline
Connect an Ammeter to the battery with everything turned off. Note how much current is flowing. The one at a time, pull a fuse and see if the current drops. If not, pull another until you identify the circuit with the draw.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K
Old September 27th, 2021, 08:12
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
I had a similar issue and it turned out to be corroded battery cables. The cable insulation hid how bad the wire itself had corroded to the point it couldn't carry battery load to crank the starter. Replaced the cables and problem solved.
Old September 27th, 2021, 11:12
thx for all ideas, really. 8mud, how should that harness be routed?? thats my #1 guess rt now. its run under the pump mounting bracket, and yes rt next to the engine. could see it getting very hot.
battery cables look solid. terminals clean. its just odd, b/c this prob just happened w pump job.
Old September 27th, 2021, 11:41
also, what is that harness? looks like exhaust sensor/s
Old September 27th, 2021, 11:42
8Mud's Avatar
Google Cruiser54, he had a write-up on routing that harness. My best advice is to route it as far away as possible from the exhaust manifold considering cable/harness length.
Old September 27th, 2021, 18:37
Awesome, will do. Ya mine is laying on it, and is melted, frayed and exposed. Also discovered that my dome light is sometime coming on and staying on randomly, regardless of whether I have it turned on or off (using the headlight knob.) Pulled the fuse. So that's definitely an issue. Is there a relay for that? Fuse looks fine.
Thanks for all the ideas, been super helpful.
- TJ
Old September 27th, 2021, 18:40
And.. that cruiser54 link is epic. Wow - thx
Old September 27th, 2021, 21:19
8Mud's Avatar
Sounds like a door switch or maybe a dome light switch. All of the interior lights are constant power and the switch switches to ground. Also take a close look at the cargo light, it has a nasty habit of screwing up mechanically.
Under the drivers side carpet, apart from the kick panel harness, are some loose wires just laying on the floor pan. The splices get corroded and the copper oxide can short the splices to ground. This can cause intermittent shorting and/or constant interior lights on with a dim light.
Old September 29th, 2021, 09:45
Black1990jeep Black1990jeep is offline
Glove box light can stay on, and drain the battery.
Make sure the drive belt is proper tension, and make darn sure it and its pulleys are not oily, spilled steering fluid may cause them to slip.
Be careful, often when a pump dies, if it sheds metal, it will then get into the steering gear. installing a magnafine brand power steering filter on the return line, this will help protect the system from debris.
Old October 15th, 2021, 20:47
Thx all. Since I've pulled the dome light fuse, the Jeep hasn't had any paraisitic drain. So that is def the problem there. Radio still not working wither tho. Fuse fine. Haven't had a chance to track those down, yet. Something is going on. But as least it's not killing my battery at the moment.
3rd Power Steering Pump replacement in one year puffydad OEM Tech Discussion 19 January 24th, 2013 05:06
Hard steering after pump replacement RenegadeStang OEM Tech Discussion 6 July 11th, 2012 07:39
replacement for power steering pump? cracked-butt OEM Tech Discussion 4 February 26th, 2011 05:44
Where/What is the best replacement Power Steering Pump? Redsnake OEM Tech Discussion 8 February 9th, 2008 15:43
Power steering pump replacement Bombero OEM Tech Discussion 2 April 30th, 2005 20:10
