krh9848
NAXJA Member #734
- Walhalla, SC
I am a noobie to the XJ and need some help on my drive shaft vibrations. I get vibration in the 25 to 35 MPH range during acceleration and a vibration similar to driving over a section of road where a bulldozer has cut tracks in the pavement when de-accelerating (this is intermittent). I have searched the forum for the answer but have found only bits and pieces of the information I need.
OK here is the setup: a 1993 with Automatic, 4.0 L HO, 8.25" Rear, RE 5.5 Lift with drop brackets, fixed UCA,s & LCA's, 231 transfer case, RE long travel yoke, stock driveshaft. Currently have 235 tires (but not for long).
I know that the best solution to my vibration problem is an SYE and I am saving up for one now but I was wondering if I could reduce the vibrations as much as possible until then. I have a 4 degree down angle on the transfer case, a pinion up angle of 6 degrees and it appears that the driveshaft angle is around 15 degrees. I have a set of 4 degree shims from RE and a set of 2 degree shims (no shims installed at present). My question is: Do I use the 4 degree or 2 degree or neither? I will need to get a 1 degree difference (pinion less than transfer case) from the info I have got from the forum searches. This means the pinion needs to be at 3 degrees up? I will need to install the shims with the thick end towards the front of the XJ to lower the pinion angle?
I really appreciate any help or advice I can get!
Thanks
Thanks
