heshhash
- Proctor, MN
so, in my 1989 cherokee, i have been in need of some front end loving on the suspension. i have put coils and shocks in. now today i got this little piece~
but i cant get the bolts loose, and i dont have a torch if i break a bolt... any tips and or tricks for you veterans when in this situation? i got most the bolts on the trackbar bracket loose, but one underneath in back, seemed to have a nut of sorts tack welded to the frame that the welds let go. i need alot more work done, but cant afford to go to the shop to fix all this stuff... without a torch or an impacter, is there any useful tricks? i have tried 4 or 5 different "rust penatraders" with no luck...
