Old June 6th, 2019, 20:26
Hurricane06 Hurricane06 is offline
Track bar frame mount
Working through installing a lift on my 99 Sport. There was no way I was getting the frame side castellated nut off. Took the bracket off instead, hoping to get the nut off once I had it off for Jeep. On a side note the axle side bolt decided to break as well. Cut the axle side bolt and got the track bar out with the frame side bracket still attached. Cut the tie rod insert below the bracket. The nut is still attached to the pressed in bolt inside of the bracket. I have a JKS Adjustable track bar to replace the OEM trackbar. Can anyone recommend a track bar bracket that will accommodate the JKS track bar? Or am I better off drilling out the bolt/nut from the OEM bracket and reusing it?
Old June 7th, 2019, 03:57
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Track bar frame mount
Is that the JKS track bar that uses a stock frame side bracket ?
If you are looking to convert to a double sheer set-up, you would need to buy a track bar bracket that has "ears" that fit your JKS hardware. Edit: ( A bit more research finds that this idea won't work with the JKS track bar, the frame end mount is fixed. )
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old June 7th, 2019, 04:15
It is the one that goes with the standard track bar bracket. I saw StinkFab had one with the “ear” at 2 and 5/8 inches wide. Going to walk out and measure the frame side bushing mount of the track bar this morning.
Old June 7th, 2019, 15:58
lazyxj's Avatar
lazyxj lazyxj is online now
NAXJA Member #1310
Remember the hole is tapered so you do not want to damage it since the JKS track bar uses the same hole.
Have you tried applying a lot of heat to the bracket and stud before trying the remove the nut?
Put a torch on it.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old June 7th, 2019, 18:26
Anak's Avatar
Anak Anak is offline
Stranger
What sort of end does the JKS trackbar use on the frame side? Does it use something like the factory tie rod end? Or something more like a Johnny Joint or heim joint?
I am running what I believe is a Rubicon Express 1600 (previous owner installed). It was originally set up with the factory track bar mount. When I plated the front end I replaced that mount with a Core 4x4 double shear bracket, rotated the heim joint, added a couple of misalignment spacers and a couple of grade 8 washers to fill out the space between the ears and it all works.
Eventually I hope to replace the heim joint with a Johnny Joint.
As long as the bar is adjustable and you can thread in a different type of end you can pick and choose the combination that best meets your needs.
Baby it's cold outside.
Old June 7th, 2019, 19:00
RCP Phx RCP Phx is offline
It bolts on vertical like a ball joint but has a end like a johnny joint, it's definitely one of the down sides. I don't believe I have ever seen a "double shear" mount for one.
Old June 7th, 2019, 19:39
Anak's Avatar
Stranger
Is it adjustable?
Can you rotate that end 90 degrees?
Old June 8th, 2019, 04:46
Tim_MN's Avatar
I did a bit more research, and the JKS track bar MUST use a stock ( or stock configured ) TB frame bracket because the rotating adjustment is at the axle end, not at the frame end. The frame end orientation is fixed.
The stock TB bracket tapered hole is drilled to a larger straight hole, and a small tapered JKS insert is also used.
I would sell the JKS track bar and purchase a double sheer design track bar. Iron Rock Off-road makes a really nice double sheer track bar.
Old June 8th, 2019, 07:51
You should go with something that has some kind of flex joint like the RE 1660 bar.
https://www.quadratec.com/products/1...m#&gid=1&pid=1
Old June 8th, 2019, 07:53
Thanks for all the feed back Gents. I was able to get the cotter pin out. I then put it on a drill press to drill out the bolt. I got 1/4 bit through the bolt, then decided to try and get the nut off. Low and behold with less bolt there was less pressure and the nut let loose. Then put it on a vice and used a c-clamp with a socket to get the pressed in bolt out. Success!!! Took it to the sand blaster and cleaned up all the rust. Painted and re-installed it.
http://https://photos.app.goo.gl/iYL77G5C7gCqp2eb9
Old June 8th, 2019, 07:54
How much lift do you have?
Old June 8th, 2019, 08:04
About 3 inches.
Old June 8th, 2019, 10:02
The JKS will work as long as your not getting crazy flex, what kit are you using?
Old June 8th, 2019, 12:42
Daystar leaf shackles and spring spacers with bielstien 5100s. New Crown OEM HD springs with new OEM coils. Old Man Emu steering stabilizer, and JKS trackbar. Going to start a build thread soon.
Bad factory Track bar frame mount Bah765 Modified Tech Discussion 16 October 22nd, 2014 20:23
Fabbing Track Bar Frame Mount Qs barillms Modified Tech Discussion 4 February 2nd, 2007 07:40
H.D. Track Bar Frame Mount jeepbme Wanted: Private Party Only 0 April 12th, 2005 05:39
Rusty's track bar frame mount Tom R. For Sale: Private Party Only. XJ ITEMS ONLY 7 February 9th, 2005 20:18
Best track bar frame mount? Goatman Modified Tech Discussion 41 August 28th, 2003 18:55
