JeepinAaron
- NC
Hey guys, well my "trusty" 4.0 has developed what I think is a terminal illness.
About two weeks ago I was driving along, came to a stop light and noticed that my "check gauges" light was on. Some investigation has led to the discovery that at idle, my Jeep only has 5psi of oil pressure. Reved up to about 2K I am only running about 13psi. When the engine is cold, right after cranking it runs about 40psi, but as it warms up to 210 the oil pressure drops to the above figures.
This is what I have done thus far:
-tested the oil pressure with a manual gauge to rule out the sending unit
-replaced the oil pump
-changed the oil with a new filter (10w-30)
-new water pump and thermostat, along with radiator flush and new fluid at an attempt to lower the engine temp
While I had the oil pump out a quick glance up into the engine didnt reveal anything out of the ordinary, but I wasnt really looking very carefully.
I took it to a mechanic, who told me it was the sending unit until i told him to test it with a manual gauge, then he told me that it was something in the "crank" and that my best bet was to drive the engine until it blew and then to get a new engine.
Any ideas? At idle, when the engine is at its lowest oil pressure I do not get any bad engine noises, nothing sounds like it isnt getting lubed. I bought the jeep used with 60K on it and since I have owned it I changed the oil regularly. Any ways to increase the pressure a few PSI? One mechanic told me to try 20w-50 oil and the Jeep place told me 10w-30.
I searched and did not see anyone with this same problem. One of the mechanics that checked it out told me this was a first for him, 5psi and no noise.
