FernGreen
- Connecticut
So I've been having this reoccurring problem with my '00 where if my jeep sits for a short period of time (5mins - 12 hrs) it cranks for a while before starting and the only thing that sometimes helps is if i push down the gas pedal as its cranking but it still takes a bit of cranking to start. cycling the ignition 3 times (aka poor mans prime) does not have any affect on the issue.
BUT...
if the jeep sits for a longer amount of time like (15-24hrs) the jeep starts right up great. Originally i thought it was the fuel pump because the check valve was bad and it would leak down below 30psi within 2 minutes but i have since replaced the fuel pump and the fuel pressure no longer drops that significantly. The fuel pressure remains over 50psi after 5 min of sitting and as soon as i turn the ignition 'ON' the fuel pressure goes back up to 56psi before starting.
I was thinking maybe a bad fuel injector but i did swap out the all injectors for a set that i pulled out of a wrecked TJ wrangler that had been sitting a couple months but had previously ran good with no starting problems.
Any insight here guys?
BUT...
