Old February 17th, 2019, 21:43
POSrenix's Avatar
POSrenix POSrenix is offline
Talking head light upgrade?
anyone have any input on headlight upgrade with thr recent rain mine are not up to par
Old February 17th, 2019, 23:01
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: head light upgrade?
Originally Posted by POSrenix View Post
anyone have any input on headlight upgrade with the recent rain mine are not up to par
Upgrade the headlight harness first, the Factory wiring is inadequately sized. You will see an immediate increase in brightness.
Upgraded headlights range from Sllverstars, to a variety of LEDs in a wide range of price and quality. Others can comment .
With upgraded wiring, H4 housings can be used which have a sharp low beam cutoff, allowing higher wattage bulbs to be used.
I have run IPF housings for years, along with Hella 80/100-watt bulbs.
https://www.quadratec.com/products/97017_1600.htm
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old February 17th, 2019, 23:32
Greenspan's Avatar
Greenspan Greenspan is offline
Yeah I second that. I haven't installed it yet but was impressed with Tims results on BleepinJeep https://youtu.be/JGf9eNK5ZYA
Old February 18th, 2019, 03:39
Mach2nh Mach2nh is offline
After you do the harness if you still want more just do us all a favor if you want LED lights then spend the money for good ones. Cheap china junk has really poor cut offs and blinds the crap out of ohers.
Old February 18th, 2019, 03:52
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
First try the harness as
Suggested, here's what I've used and I really like the build quality.
https://www.amazon.com/d/Wiring-Harn...ght/B00BMN30HY
Now this amped my silverstar lamps to a highly noticabl difference, However after seeing what my light bar does, ide like LED. I do not have any h4 experience to offer I wish there were more comparisons.
Old February 18th, 2019, 11:06
POSrenix's Avatar
LOL i just ordered some LED for 100$ on ebay then saw your post about bleeping jeep and upgrade the harness im impressed may revert back to stock and do the harness that harness trick looks like a universal product i will probably get this as well for another vehicle now that im aware of it
Old February 18th, 2019, 11:14
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
+1 on the harness. I'm running it with stock sealed beams and really happy with it. Ran it with silverstars on my last XJ and it was almost too bright.
John V.
RRC VP
DAL
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old February 18th, 2019, 11:37
Hypoid's Avatar
Hypoid Hypoid is offline
Last time I changed a headlight on my RENIX Jeep, I measured a 2-1/4 Volt drop from the battery to the headlight. Not running that current through the switch on the dash makes a huge difference.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old February 18th, 2019, 12:17
bentroia bentroia is offline
1, Harness
2. Lamp and Bulbs
This Headlight Services harness is XJ specific, high quality, and installs easily (a hour or so) with a factory like finish. http://www.headlightservices.com/CherokeeHarness.html
I also installed Hella E-Code lamps and some 55-100 Osram bulbs. My experience with installing high quality lamps and bulbs without the harness made only a slight difference not any real upgrade - due to the inherent voltage problem in the XJ..
The lights on my XJ are now very bright, safe, and there is no need on my Jeep for any additional lighting system.
Old February 18th, 2019, 16:58
trippled trippled is offline
Agreed. I just loooovvvveee the "how many LEDs can we cram in this housing" so called upgraded lights.
Old February 19th, 2019, 07:14
sixditchoffroad's Avatar
sixditchoffroad sixditchoffroad is offline
AKA Skip
Hahaha, absolutely. I did the "LED" route... waste of money.
Old February 19th, 2019, 09:14
denverd1's Avatar
denverd1 denverd1 is offline
that's surprising. which ones did you go with?
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old February 20th, 2019, 10:44
freerider15 freerider15 is offline
This really depends on the housing and LED's used.
I've got some Amazon (Beamtech) drop in LED's in Hella E-Code H4 housings.
The light is great, and the cutoff just as good as incandescent bulbs.
I did try the same LED's in Autopal housings...complete crap.
I run Beamtech LED's as well (Amazon) in my F-350's housings. Cutoff on those is fantastic as well. HID's in those housings...crap.
I love LED's, less draw and better light.
That being said, I'm a huge fan of Hella E-codes, a harness upgrade, and Hella 90/100W bulbs. Ran that setup for years before the buggy was a buggy. You can find the Hella bulbs rather cheap as well (like less than $10 a pair), since the higher wattage bulbs have a shorter life.
Old February 21st, 2019, 14:15
lazyxj's Avatar
NAXJA Member #1310
Do the Beamtech LEDs, for the E-code housing, fit without trimming the back of the headlight buckets?
I have used IPF housings for years and like the cutoff, the Autopals are junk in comparison, thin glass, poorly focused and easy to break.
https://www.amazon.com/BEAMTECH-Head...ct_top?ie=UTF8
Old February 21st, 2019, 14:27
Ronbo's Avatar
Ronbo Ronbo is offline
I ordered this harness from Amazon, it's actually a Hella product. Far nicer than the Putco harness I've used. And yes, the pictures on Amazon are not what I actually got.
http://tinyurl.com/y5t66zwy
98 4.0, AX15, 241OR, RJ44/RJ60, Poly 3-link, Nationals, 35s.
Speaker upgrade w/ stock head unit? BALTANAKT OEM Tech Discussion 9 May 7th, 2018 18:57
Head light upgrade ?'s comanche24 Modified Tech Discussion 2 June 30th, 2011 21:47
Problems with Go-Jeep Head light upgrade J-Roc Modified Tech Discussion 5 May 24th, 2009 09:13
Wagoneer head light upgrade. XJRunner Modified Tech Discussion 1 November 5th, 2007 10:09
Fog light upgrade 94XJManny OEM Tech Discussion 11 August 8th, 2003 13:27
