Old February 6th, 2004, 11:15
LiquidOps LiquidOps is offline
Will they mate?
Will an aw4 from an 87 mate with the motor from a 92 without any problem?
Thanks in advance
Old February 6th, 2004, 11:17
Gary E's Avatar
Gary E Gary E is offline
NAXJA Member #687
I don't think you will have a problem with that but you will have t-case spline count issues
Old February 6th, 2004, 11:20
I will be dropping in an 87 tranny with tcase as a set to do the 4wd conversion on my 92.
Old February 6th, 2004, 11:25
XJTripp XJTripp is offline
What about the computer? Looking at some of the posts regarding manual overide of 2nd gear in the 1-2 position on the shifter, I encountered a warning of "don't try this on a post 1991 vehicle or it will damage the transmission." This implies a difference in either the computer, wiring or mech. operation. I would check this out.
Old February 6th, 2004, 12:47
5-90's Avatar
5-90 5-90 is offline
Mechanically, they'll mate - the basic 242I6 block didn't change thruout its entire production run.
I'd like pix of the kids, tho...
5-90
Old February 6th, 2004, 14:29
Neil's Avatar
Neil Neil is offline
If I'm not mistaken on pre 91 models there is a TCM located under the glove compartment/cubbyhole on the passenger side. On 91 and newer models automatic transmission control was relegated to the ECM. You may need the TCM from the 87.
Old February 6th, 2004, 18:03
I do have some sort of "computer" located below my glove box. I've noticed it when i had to drop the lower panel to run some wires for my speakers. Is that what you are talking about?
I have a 92 XJ 2door Sport.
Old February 6th, 2004, 18:23
NN4S's Avatar
NN4S NN4S is offline
XJ Afficianado #789
There's also the speedo drive to consider; the 87 is mechanical drive while the 92 is electronic, so if you'll be driving it on the street you'll need to make some other changes as well. I'm not sure if there's a simple way to change things around or not, maybe the mechanical cable can be plugged directly into the new trans but I haven't done it. I guess if the case hasn't changed it'll fit...
Don T. NN4S
2001 Solar Yellow 2-door, auto w/6" Rock-Ready lift, 4.56 w/No-Slip & 33" BFG AT/KOs
1994 Navaho Turquois 2-door, auto w/4" Tomken lift, 3.73 Trak-loc & 31" Dunlops
_________________
Old February 7th, 2004, 04:11
Amund2 Amund2 is offline
Speedo's fine, the electrical pulse thingy for electronic speedo is attached just like the speedo wire, unscrew one and plug in the other.
Both aw4's have a computer, the same AFAIK. But the old AW4 had a "comfort" switch which the HO (1991+) don't have, so something is different with the wiring, and probably the computer as well. Now the interesting question is - do the old AW4 interface with the engine harness the same way as the new? I know the AW4 reads the TPS among other things. I'm not sure about this.
Old February 7th, 2004, 17:07
EEEEEEK!!! I need to know ASAP. I have to let the guy know as soon as I can... HELP!!! it's one heck of a deal... i just need to know if it's gonna work !!!
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
